Go Back   Automotive Forums Car Chat > Chevrolet > El Camino
Old 12-16-2010, 12:44 AM
henmar77 henmar77 is offline
Water In Cylinders
350 Chevy El Camino. Engine over heated. Blew the water pump gaskets. Changed thermostat and water pump gaskets (water pump is fine). When I cranked the engine it wouldn’t start pulled the spark plugs, water poured out of 2 of the middle cylinders on the right side. Took off the heads, no cracks. Took off the head gasket, don’t see any damage (as far as I know other than cracks or breaks not sure what to look for) Examined the block don’t see any cracks. So where is the water coming from? I don’t know what else it could be. I’m afraid to put it back together again with new gaskets without knowing what’s wrong. What else could it be?
Old 12-16-2010, 12:50 AM
big dwag big dwag is offline
Re: Water In Cylinders
When you check it for cracks did you take it a shop? A machine shop can check it & fix it for little to nothing. Its hard to tell by just looking at it with your eye. I know i have had the same problem before.
Old 12-16-2010, 08:16 AM
MrPbody MrPbody is offline
AF -Advisor
Agreed that the heads should be "pressure tested". When fully assembled, it's difficult to accurately magneflux them. Our machine "seals up" all the water passages then "charges" the water jacket with high pressure air (40-60 PSI). It then "dunks" the head, not unlike checking a tire for leaks. You cannot rely on a "visual inspection" when this happens. Small block heads are notorious for cracking in the middle cylinders, around the exhaust valve seat. We charge $75 to test the pair. Prices vary from one part of the country to another.
If they show no cracks, they WILL still require resurface. The "minimum" is recommended to make them "flat" again. No need to mill off "extra".
It is also possible there's a vertical crack in one of the offending cylinders (or even both...). The piston must be "all the way down" to look for this. A flashlight and crawling into the engine compartment are called for to do this.
Replace the head bolts! Though it isn't "required" (as with many modern engines), they are no less than 30 years old, and who knows how many times they've been removed and installed. New ones are relatively cheap (about $35 for the whole engine). No need for aftermarket performance bolts. Stock "replacement" are good.
Don't "scrimp" on gaskets, either. Felpro or Victor/Reinz are what we use here.
Jim
Old 12-16-2010, 10:48 AM
Scrapper Scrapper is offline
AF Premium User
if your going to replace head or head gasket take it to the shop and let them do a dye test on it for cracks or you may see it rite away when you get it off. i bet thats missing like a mother f.....
Old 12-20-2010, 08:05 PM
j cAT j cAT is offline
when the engine overheats the heads can be damaged by getting distorted. you have to send these out for testing.
very possible to shave heads if not too bad .. then you must use a head gasket to compensate for the trimming if it is done..
when you re install all of this do not add any water. then do the compression test. then you will know if you have a problem..no compression problem !
with water getting into the cylinders after overheating this is most always a head gasket / head defect..
an engine with water and no antifreeze in freezing temps this would be a cracked block ..this is common with boaters not properly draining the engine and placing antifreeze into the engine for winter storage ! this also gives the same result.
using old bolts on a head change after overheating is not good !
Water Cylinder Decarbonizing... Should I? BlazerLT How-to | Technical Info 58 02-27-2011 10:34 PM
Ignition Lock Cylinder & Worn Keys... Intuit Escort 2 02-18-2009 09:51 AM
water cylinder decarbonizing.. how much? unknown_sender12 S-10 1 04-23-2005 10:34 PM
Water Cylinder Decarbonizing... Should I? BlazerLT S-10 5 09-07-2004 11:26 PM
