Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-15-2010, 09:03 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
4L80E Harness Adapter
I am working on my father in laws 1991 Chevy suburban 3/4 ton 4x4 6.2L Diesel w/ 4L80E transmission.
He replaced the filter/fluid and lost reverse, couldn't figure out why so he asked me to replace the transmission, he got a used transmission from a local yard (the only one that had one), it came out of a 93 pickup w/ 5.7L, well the main harness plug is different.
The old tranny has a 12-pin connector w/ center bolt. the new one is a 11-pin and just clips on. Anyone know why they are different or where I can buy an adapter for it. I know they make adapters to go from the 4L60e to a 4L80e.
I do know the new transmission is a remanufactured transmission (has a sticker on it) so that could be why it has a different harness.
any suggestions?????
Joe
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 12-16-2010, 06:05 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 4L80E Harness Adapter
The old tyranny has a 12-pin connector w/ center bolt. the new one is a 11-pin and just clips on. Anyone know why they are different or where I can buy an adapter for it. I know they make adapters to go from the 4L60e to a Le.
Joe
Are both old and new transmissions 4L80E setups?
I would use the wiring from old transmission.
If you still have the transmission that came out of it remove the wiring inside wiring harness and plug-in from it.
And Also check the solenoids and sensors from old transmission if the new transmission solenoids are different.
MT
Old 12-16-2010, 06:56 PM
Elbert Elbert is offline
I don't think the 93 with 5.7 came with a 4L80E trans? Both trucks 3/4 ton? I may be wrong but... I think there were some changes around the 91 / 92 year model.
Elbert Clarke
Old 12-17-2010, 05:10 PM
AutoTrans AutoTrans is offline
GM changed the harness in 1993 from a 12 pin to a 11 pin as they were experiencing a transmission leak. You can either replace the 93 harness with the old 12 pin harness or what is recommended ... buy a 4L80E transmission repair end for 1994-2002 vehicles ....runs about $50 from electronic advantage. See eBay. You have to cut the connector wiring harness and splice in the 11 pin connector... only cut one wire at a time....you will have one wire left over you just tape off. Make sure there are instructions included....you need the pin out.
Bill
Old 01-06-2011, 03:34 PM
4arkraft 4arkraft is offline
Difference is as someone commented early (12 pin) vs later (11 pin) 12V+ power was on 2 pins early-pins C & K later style put 12V+ on one pin only-pin E
A diagrahm of the plugs with each pins ID letter and a chart of of the funtion of each pin (by letter) may be viewed at www.pirate4x4.com
search the forum thread YJ wrangler 6.0L 4l60e rewiring harness This may be bulletin board#post8030893 It address converting for a 4l80 from a 4l60 but contains the info on early & later plugs.
harness adapters mixedchick Classifieds 0 04-26-2006 09:30 PM
monsoon radio/cass to radio/cass/cd harness adapter? gowake Passat 0 03-06-2004 03:51 PM
head's up for you OBD0-OBD1 guys.... harness adapters.. marked001 '88 - '91 Civic | CRX | Wagon | Shuttlee 6 01-30-2003 05:43 PM
P10 G20 Radio Harness Adapter A380Driver Classifieds 1 02-20-2002 11:14 AM
Dash adapter, wiring harness, antenna adapter frogg Audio/Security 0 10-24-2001 11:36 PM
