Old 12-15-2010, 07:54 PM
steve0490 steve0490 is offline
heater core feed
ok i have a 96 block in a 94, ive converted it to carburator, ok looking at the block which port on the water pump does the heater core get its feed from the left or the right
Old 12-16-2010, 05:45 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: heater core feed
From memory which sometimes is weak.
Water pump heater hose port is usually a suction feed or return from heater core.
The pressure feed to heater core will come from intake water port.
Sometimes rear intake and can be on front on older intakes.
But to double check pull heater core hose that comes from intake and see if it is pumping water/coolant out end to heater core.
MT
Heater Core Help emmaandleesmom SC/SL/SW 3 04-01-2010 11:43 AM
2002 Saturn L 300 heater core replacement Dadsvan LS/LW 0 03-22-2010 11:17 AM
97 k1500 z71 silverado, BLOW THE HEATER CORE???? kokopelli85 Silverado 6 01-12-2010 07:38 PM
1998 ACHIEVA Heater Core darkflame64 Achieva 1 12-31-2009 03:05 PM
smell antifreeze - NOT heater core samdavon Dakota 1 12-11-2009 12:19 PM
