Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 12-15-2010, 11:32 AM
magpi1 magpi1 is offline
99 cv p71..lights flicker update.
alternator is good.. battery is good... checked all grounds, cleaned post.
alt is charging 14.8/15 volts. does not dip. charges higher with a/c on.
Now I turn lights on and they flicker but alt does not dip.
With lights on and turn signal on the battery needle in the dash does
bob a little up&down.It does the same on my volt/ohn meter.
I did notice my panel dim switch above the headlight switch has no effect
on the dash lights (does not dim dash lights).
Has anyone had this problem? I do. all help is welcome.thanks
Old 12-15-2010, 12:42 PM
urclueless urclueless is offline
Banned
Re: 99 cv p71..lights flicker update.
yep, I use an oscilloscope to see what the waveform looks like from the alternator. Significant ripples will cause your exact problem
Old 12-22-2010, 11:41 AM
Yep..It was the alternator. must have been in the voltage regulator side.
Put the new one on and no problems now.
Got It off ebay from a place called crank-n-charge.Good price & free shipping.
Also no core charge.
Thanks for all the help guys.
Old 01-24-2011, 05:53 PM
lights_sirens's Avatar
lights_sirens lights_sirens is offline
Oh, I see you got it fixed now. Good deal. Glad to see you got the free shipping too!.
1999 p71 cuts out temp light coms on, car dies/ stalls usedcopcardudenj Crown Victoria 3 08-09-2009 07:23 PM
what works for a 2000 P71? jx426 Crown Victoria 6 03-17-2009 04:34 PM
99 P71 Wheels & 03+ P71 Wheels redcar Crown Victoria 4 08-18-2006 09:14 PM
Lights Flicker, Battery Light Flickers, etc. smitty425 '88 - '91 Civic | CRX | Wagon | Shuttlee 5 11-26-2003 07:09 AM
Lights flickering FreakinWindows Blazer 2 05-28-2003 05:05 PM
