Old 12-14-2010, 09:51 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
where is the washer fluid pump?
I know I should know this...but I cant find it! Granted I havent looked too hard because its freakin' cold, but If I knew where to look it would sure be nice.
I cant seem to get any activity when I push the washer button. I cant hear the pump running either. For the moment its not unreasonable to assume its frozen, because I tend to run either straight water or a water/blue mix during the warmer months, and sort of forgot to add in some blue...and it hasnt been above freezing in a week or more here.
Id like to find the pump to check for wiring problems, and possibly replace if necessary....thanks!
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 12-15-2010, 08:51 AM
pfofit pfofit is offline
Re: where is the washer fluid pump?
It's at the bottom of the washer reservoir. Look for a cable coming out and up near there.
Sounds frozen and if'n so, then the lines are most likely as well.
If it was easy, then anyone could do it.
Old 12-15-2010, 12:22 PM
LittleHoov's Avatar
Looks like its good and buried..thanks for the pic!
Im hoping its just frozen too, but ya never know. Couldve trashed the pump if it froze up bad inside it.
Old 12-15-2010, 07:19 PM
LittleHoov's Avatar
Well it finally warmed up into the upper 30s this afternoon, quite balmy if I do say so.
Pump started working again, filled it up with the blue stuff and let it run for a while...hopefully it wont freeze again.
Thanks for the help anyway.
Wagon-Rear Washer Fluid Pump lrk1000 Taurus | Taurus Wagon 1 01-05-2006 09:11 PM
95 Transport - Washer Fluid Pump Icarus3000 Trans Sport 6 11-23-2005 09:08 AM
Washer fluid pump Orionsax7 Sonata 0 06-09-2005 07:54 PM
washer fluid pump circuit. ironran Intrigue 4 01-21-2005 05:15 AM
Washer fluid pump quyonmob Metro 4 01-19-2005 05:05 PM
