Go Back   Automotive Forums Car Chat > GMC > General Discussion
Old 12-13-2010, 09:53 AM
antlerfreak antlerfreak is offline
99'GMC 3500 Van multiple failures
My Van lost power steering and brakes at the same time, the belt is fine and the pully to the pump is turning smooth. And at the same time the break peddle got very stiff but without giving much breaking.
There is a hose that goes from the power steering fluid resivore to the master cylider I believe. Is it possible the two problems may be the result of one problem.....master cylinder or something close?
Thanks
Old 12-13-2010, 11:42 AM
maxwedge maxwedge is offline
A990 racer
Re: 99'GMC 3500 Van multiple failures
You have Hydro boost braking, either you have no fluid in the p/s pump or the pump has failed, you would loose the brake boost and p/s if this happens.
Old 12-13-2010, 12:09 PM
I had a feeling something like this was the case. Thank you.
The pump has plenty of fluid, and its not making any noise and appears to be fine while running, can or do these go out, without making noise and the pully still turning fine, or could it be a blocked hose or line?
anyway to find out without going through the hassle of replacing the pump to find out?
Thanks
Old 12-13-2010, 07:05 PM
A990 racer
The pump should be pressure tested with the proper gages for an accurate diagnosis. The shaft coud have broken internally, somewhat common issue.
96 Dodge Van 3500 Automatic Transmission Failure vince2010 Ram Van 7 01-14-2013 03:12 AM
97 ram 3500 van issues Lola66 Ram Van 2 04-19-2005 10:24 PM
Help - Brakes lock up on 1997 3500 van LlamaLadySG Ram Van 1 04-19-2005 10:05 PM
Help - Dodge Ram 3500 Van brakes lock up LlamaLadySG Ram Pickup | Ram SRT10 2 04-01-2005 05:57 PM
2002 Express 3500 Van High Idle TimiN467 Express | G Van 1 02-07-2005 04:55 PM
