Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 12-12-2010, 08:32 PM
extremetimmy extremetimmy is offline
2002 Seirra Tow Button not working
Just picked up a 2002 Seirra and found out the tow button doesn't work. When pushing the button, nothing comes on in the dash and the tranny doesn't kick down. Does anyone know where to start to trouble shoot this? Thanks
Old 12-13-2010, 07:56 AM
maxwedge maxwedge is offline
A990 racer
Re: 2002 Seirra Tow Button not working
Assuming the trans is in good shape is not slipping and has all 4 gears, it will need a scan with a trans function scanner to see if the command is reaching the trans and controlling the involved solenoids in the valve body.
Old 12-14-2010, 08:56 AM
artrip36 artrip36 is offline
remove lower steering column cover. there is an orange wire with 2 small white wires inside. look for cracks and broken wires. very common
Old 01-09-2011, 02:14 PM
slo99sierra slo99sierra is offline
^This. The wires pinch and separate from the tilt and shifter movement. You will have to solder (they are too small to crimp, 22 gauge wire) them together. Take the dash bezel off, then the column covers and kickpanel for easy access.
Take a torx driver or torx bit (don't remember what size) to the shifter at the column, take it out of the column. Find your broke wires at the column, trace it, and unplug from the column. Commence your soldering.
95 Millenia Keyless Remote 2 buttons not working XCkid87 Millenia/Xedos 9 0 12-03-2004 06:16 PM
4hi dash button not working on 97 Jimmy Jimba61 Jimmy 7 12-02-2004 08:53 PM
Heat and Air control buttons not working. specialist1922 Accord/TSX/Accord Hybrid 0 06-21-2004 07:03 AM
Need help setting clock. Memory button not working FISHER1 3 Series 0 06-18-2004 10:32 PM
Tow haul not working martink C/K 1 06-02-2004 01:52 PM
