Old 12-11-2010, 08:02 PM
Chen's Avatar
Chen Chen is offline
Battery drain on horn/brake light circuit
My voltmeter reads .392-.40 and when I pull the 15 amp fuse for the horn/brake light circuit under the hood it reads .013-.014.
If I leave the fuse in and don't drive my car the next day, the battery will be dead. Disconnecting the brake light switch and also the horn at the steering wheel doesn't change anything.
Any ideas? Any specifics on what route the wiring takes between the fuse box under the hood and the brake pedal?
89 CRX SI - ZC DOHC, lambo doors
89 CRX DX - H22 in the making
04 G35 Coupe
Old 02-20-2011, 01:01 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Battery drain on horn/brake light circuit
don't know if you are still looking for an answer ... did you try disconnecting the brake switch under he pedal ? It may also have a relay that is "leaking"
Old 02-20-2011, 01:09 AM
Chen's Avatar
I actually did try that too. No change. I carry a fuse puller in my pocket and have been poppin' the hood and pulling the fuse when I'm done driving the car for the day. Kind of annoying.
I could just put a switch on that circuit, but then I still haven't fixed the problem. (I'm a bit OC)
I may investigate the horn switch some more. Sometimes the horn don't work, almost like it's not getting good contact when I push it. Of course when I take it apart, it all looks good.
We wouldn't develop loving relationships with our cars if they never screwed us.
04 G35 Coupe
Old 02-20-2011, 05:23 PM
Audio Guy
the horn has a relay, try pulling that and see what the current draw is. Just out of curiosity, do you have an aftermarket alarm ?
Old 02-22-2011, 02:09 AM
Chen's Avatar
Where is the horn relay? I have disconnected the horn at the steering wheel and at each of the horns behind the bumper and get no drop on the voltmeter. I also disconnected the brake lights and the switch at the pedal. I pulled each fuse under the dash and under the hood one at a time with no effect. The only fuse that changed the reading was the 15amp fuse under the hood for the brake light and horn circuit.
I do have an aftermarket alarm. It doesn't work right now. I have considered this as a culprit, but have ruled it out because I don't see a link between the two that looks problematic. It's possible that I've overlooked something though.
04 G35 Coupe
Old 02-22-2011, 07:00 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Try the brake switch at the emergency brake handle and try to remove both the ground and positive from your alarm.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 02-22-2011, 05:54 PM
Audio Guy
there is a relay either under the dash or under the hood for the horn can't remember which. The alarm can sometimes have auto-start that may be tied into the brake switch. Just because the alarm is disbled does NOT mean it's harness is not still wired up - try pulling the harness(es) out of the brain box to see what happens.
1999 Passat - Changing Brake light bumpsetspikeki11 '97+ 0 03-09-2010 08:38 PM
no horn, brake lights or cruise control gsir2000 Integra 3 03-01-2008 08:28 PM
01 GC battery drain from hazard lamp circuit coyote54 Caravan | Voyager 0 09-17-2005 04:14 PM
Brake Light Circuit Failure bjchacha 3 Series 1 10-24-2002 07:56 AM
