Go Back   Automotive Forums .com Car Chat > Nissan > Altima
Old 12-11-2010, 05:04 PM   #1
cowpie
Fuel line replacement.
Greetings, I found a leaking fuel line where the rubber hose connects to the steel line under the car. I disconnected the line at the fuel pump and the steel line, but it won't pull thru. I am sure they are the same line as the fuel line on both ends is smaller and has screw tightened clamps. The vapor lines are larger and have squeeze clamps. Do I need to lower the gas tank or should it just pull thru?. Thanks in advance. 95 Altima
Cowpie
cowpie is offline   Reply With Quote
Blend Door replacement on 1998 Chevrolet Blazer nitacarter Problem Diagnosis 2 12-11-2010 09:16 PM
