Old 12-11-2010, 11:08 AM
p31186 p31186 is offline
Car shuts off with turn signals
I have a problem with 01 intrigue. When I turn on a turn signal the car shuts off. It does not have any of the dashboard lights on, so can't check it with the scanner. What could be causing this problem?
Old 12-11-2010, 06:48 PM
sparcx sparcx is offline
Re: Car shuts off with turn signals
http://workshop.search-autoparts.com...76047&d=339500
i did a google search and i found a 2000 pontiac thread that had a similar problem that resulted in replacing the ignition switch. Check that topic out and see if your symptoms match up.
If the symptoms match up, i would definitely consider getting the ignition switch checked out as it commonly causes problems in the intrigue. There's a number of ignition switch topics for the intrigue on this forum. Might want to also eliminate some of the other things that guy checked out in his testing process.
car shuts off, when headlight is turned on foon Corolla/Matrix/Voltz 0 12-04-2007 05:51 PM
Brake lights out/cruise shuts off when changing lanes with turn signal??? busdriver Venture 3 02-26-2007 04:30 PM
Vent turning on after car shut off chevygirl628 Lumina 5 04-20-2006 09:19 AM
Installing Sirius, want it to shut off with thte car lehmannd Explorer | Explorer Sport Trac 1 01-19-2005 02:26 AM
Car shuts off and turns back on ashah000 Eclipse Problem Diagnosis 3 12-15-2004 07:08 AM
