Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-11-2010, 12:25 AM
pollitoeclipse pollitoeclipse is offline
Question i have a 96 talon gs turbo but will not start it has fuel and spark but will not start
hi i have a problem with my talon ..i just bougth this car as a project car.. it has a 40 trim turbo kit on it 5 speed but the problem is that i cant get it running it cranks. it has fuel and spark ,,also a new timing belt and ecu ,asd relay and cam sensor.... i havent check the crankshaft sensor and compression but do u think it could be something else?
anything will be very helpfull...thank you
Old 12-12-2010, 11:24 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: i have a 96 talon gs turbo but will not start it has fuel and spark but will not start
Do a compession test and see what the numbers come out to be.
Did you change the timing belt?
I assume it didn't run when you bought it?
Crankshaft position sensor also plays a large part in no starts as well.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 12-14-2010, 11:20 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
If it was the crank position sensor it would not be getting fuel or spark so you can rule that out. I would do a compression test, the timing could be off
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
No start, has spark, has fuel, only when warm? anyone? ateball7 Achieva 0 02-14-2009 09:19 PM
87 Celebrity Won't Start. Has Fuel and Spark, No Go. Brokecelebrity Celebrity 8 01-30-2008 11:20 AM
1987 F150 5.0 liter NO start when hot, new ignition did not help, has fuel & spark.. chubbygoatboy F Series 4 04-18-2007 02:35 PM
Have Fuel and Spark, But No Start??? boostaddct Malibu 8 12-16-2005 11:08 AM
88 S-10 cranks/will not fire/has fuel & spark kevleasa S-10 9 06-02-2005 01:14 AM
