Go Back   Automotive Forums Car Chat > Subaru > Forester
Old 12-10-2010, 07:18 PM
SsHaDyGt SsHaDyGt is offline
My firneds Forester won't start and alarm going off
Hi all,
I have a friend who called me and asked for my help. He has a 2001 Subaru Forester. My friend disconnected the battery to repair something with the spark plug.
After reconnecting the battery, he says that the alarm is going sounding and the car won't start. I'm guessing there is an imobilizer.
He told me that the keyfob says part number 88035ac231
Has anyone seen anything like this with their Foresters?
Thanks
1998 silver gtp, GM performance Handling kit ,cold air intake, KYB struts ,HD supercharger coupler ,Gatorback belts ,U bend delete ,NGK TR6 plugs ,DHP PCM, Electric exhaust cutout - SOLD
98 White GTP, N* TB, 3.0 MPS pulley, SLP headers, 1.9 Rockers, 105# springs, ZZP PCM, Flowmasters, GM performance Handling kit, FWI, GMPP springs, U bend delete, SSIC, Ported LIM, Autolite plugs, ported SC, 12" brake upgrade with slotted cross-drilled rotors,
Old 01-02-2011, 01:17 PM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
Re: My firneds Forester won't start and alarm going off
I know I'm late to respond, but had they tried disconnecting and reconnecting the battery again to see if it made any changes? Did they ever figure it out? Let us know!
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Old 07-03-2011, 04:18 PM
hobo26 hobo26 is offline
When the Forester battery cables are disconnected, it clears the memory of the cars computer, when reconnected, the computer alarm will go off, Look for a small push button switch just to the left side of steering wheel, and just under the lower dash.. turn your car on to the assoc. position, or start it, then push the little bottom under dash to reset the alarm.
The complete system, gas regulation, etc. also needs to be reset after battery has been disconnected.. Start car and with foot on bake, and emergency brake set, put car in N then into Drive and let the car warm up sitting there, once showing the needle to have moved to start warming up, turn on air conditioner to let the computer reset RPM for the air conditioner.. That's it.. the computer should have reset all values of sensors and operations.
Note.. If anyone has changed their own timing belt w/ gear pulleys & tentioner, also needs to know this procedure for resetting the computer before car will run correctly.
Hope this helps...
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 04:20 PM
'97 astro won't start and dashboard lights off santiag M Bodies 2 01-02-2008 12:53 AM
96 GrandAm Won't Start & Alarm goes off constantly JM22 Grand AM 1 03-17-2006 08:41 PM
Car died while in motion, now it wont start and alarm is going off!! roxydrew Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 02-13-2004 03:46 PM
