Old 12-10-2010, 02:38 PM
Pelton Pelton is offline
Rob
I have a 2003 S-10 blazer that after a few miles of driving kicks out the transfer case and only will move if shifted to 4low after a few miles will swith back to 2 wheel but will kick out after a few more miles. 4 low work good but will not stay in 4 high or 2 wheel drive. T
Old 12-11-2010, 09:10 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Rob
Are you driving it in 4W on dry highway?
Auto Matic Transfer case with auto button on shift control panel?
Any lights 4W lights or service sone lights blinking or on?
How many miles and has transfer case fluid ever been serviced?
You.
May need to get it on a transfer case transmission capable scanner and get codes and see what is going on.
Post back any codes for the engine or ABS or tarnsmission or transfer case.
Also check all power supply to it and fuses and wiring.
MT
Old 01-10-2011, 12:53 PM
Re: Rob
I should go into more detai, The Blazer drives down the road with no problems until going down a hill and it shift out of 2 wheel drive or 4 HI but will shift into 4 Low with no problems. The only way to get it to shift back into 2 whell or 4 HI is to come to a stop and place the trans into nuteral and the transfercase into 4 LO then into 4 HI OR 2 wheel drive it slips right back in but only if you do it that way. I have replaced the contoler on the transfercase and the box down by the passengers feet. I have been driving the Blazer only in 2 wheel drive with the only time changing is to place it in 4Low to shift it back into 2 wheel. I have not had any lights blink and it is a three butten system.
Old 01-10-2011, 01:29 PM
MT-2500's Avatar
AF - Advisor
Re: Rob
You can check the 3 button transfer case for codes by grounding pin 13 and watching the shift button light flashes.
Count the flashes and post back.
Has the shift button switch been checked or tested?
Have you checked all wiring for any shorts or bad spots?
Start it up and get it in two wheel and then unplug shift button switch and see what it does with switch unpluged.
MT
Old 01-10-2011, 01:43 PM
Re: Rob
How do I locate Pin 13? and I have checked for a bad spot in the wiring.
Old 01-10-2011, 02:14 PM
MT-2500's Avatar
AF - Advisor
Re: Rob
http://www.troublecodes.net/OBD2/
MT
Robbed? sparq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 06-03-2002 01:55 AM
Someone robbed my local hobby store Macka Car Modeling 4 02-19-2002 07:49 AM
Any ROB ZOMBIE fans here? KatWoman COMPLETELY off-topic 10 11-18-2001 07:45 PM
I've been Robbed MercCougarXR7 COMPLETELY off-topic 5 10-29-2001 06:45 PM
