Old 12-09-2010, 09:05 AM
cameo58 cameo58 is offline
PVC Valve
I installed a '91 Corvette 350 ci in my cameo with edelbrock intake and road demon jr. 625 carb. The carb has one 3/8 vac. outlet which I'm using for the power brake boster. I want to install a pcv valve in the edelbrock valve cover on the driver's side. I have a edelbrock breather cap in the passenger side cover with a hose to the bottom side plate of the edelbrock air cleaner.
I've checked and didn't locate any provisions for vacuum outlets in the manifold runners or on the carb to connect a hose from a pcv if installed on the driver's side valve cover.
Would an additional carb base plate with provision for tne second vacuum line take care of this, What about a second location on the air cleaner base.
I would appreciate your help with this matter.
Last edited by cameo58; 12-09-2010 at 04:04 PM. Reason: Question has been answered. Thanks
Old 12-10-2010, 04:41 PM
534BC 534BC is offline
Re: PVC Valve
The plate under the carb would be the place to do it and ideally would pull equally from both sides (barrels)
Any port that pulls from both banks.
PVC Valve Location / 2000 Silverado 4.8 ltr davideo C/K 2 05-16-2004 04:30 PM
PVC Valve cruiser69 Grand Prix 1 03-08-2004 09:05 PM
How to change PVC valve? mulepacker Ranger | Courier 3 01-09-2004 07:01 AM
PVC Valve Replacement - Help!! zigm28 Grand Prix 3 12-15-2003 01:04 PM
clutch replacement for 1990 sentra, also WTH is the PVC valve on this? chefantwon Sentra | 200SX (USDM FWD) 2 07-16-2002 03:38 AM
