Old 05-22-2003, 10:39 PM
jdmhondaonly jdmhondaonly is offline
internals---JDM or not????????/
I recently have obtained enough money to overhaul my engine and turn it into a street driven low 13 high 12's vehicle. I need some opinions on what to do. Let's start off with what I have already. It's a B18C JDM type R motor. Stock except for intake, exhaust and a chip it pulls 14.2 in the quarter. That's with my original GS-R tranny from my grenaded motor of the past. So this is what I have in mind. A type R tranny with LSD from factory. That's a big chunk of the money. Then with the rest of it, I can get a lightweight flywheel, 6 puck clutch, civic type R pistons, new rod bearings, and a civic type R intake cam. Will that be strong enough to run low 13 high 12's. Anybody else has suggestions????? I don't want anything extreme that I can't afford like fully port and polish with oversize valves on my head, or wild cams that would need upgrading my valvetrain.
Old 05-23-2003, 10:33 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
you wont hit 12's with those extras but very high 13's are possible, add slick and you should be mid 13's
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-06-2003, 08:31 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
you'll hit high 13s with the set up you just mentioned. If you wanna be fast it requires more money! If i was i would save up and invest skunk2 stage 2 cams along with there upgraded valvetrain. Ctr pistons is a good choice also. SO with the set up that i mentioned you'll hit low 13s possibly high 12s with drag radials. IF you gonna spend like 1500 on a type r trans thats not gonna get you into the 12s or 13s. Maybe 14 flat but thats all u gonna see. So with that 1500 thats the whole skunk2 set up right there!
Old 06-09-2003, 10:28 PM
ssshhhh (_burn_)'s Avatar
ssshhhh (_burn_) ssshhhh (_burn_) is offline
Send a message via AIM to ssshhhh (_burn_)
Re: internals---JDM or not????????/
what car is the itr motor in? if its in a light car like a hatch or crx....you should be in the 13's already. alot of the things you listed are good except the 6puck clutch.... it will put more wear and tear on your brand new type r tranny your dumping money into. a stage 2 or 3 clutchmasters should be FINE for that car.
6.7 @ 211mph whooping kubo's ass all over the track
Old 06-18-2003, 11:37 PM
funkdaflex1 funkdaflex1 is offline
Try working on your drag skills like try different tecniques driving down the track my buddy has a teg type R and he runs a 13.7 with vtec controler, jdm header, apexi n1 ezxhaust and cold air intake. he just reads up on driving skills man totaly awsome driver... just try and learn the skills i know i am.
SOLD
V
D16y8-
-Greddy Turbocharger
-Greddy front mount intercooler
-Greddy type S BOV
-Greddy profec E-01 boost control
-Apexi N1 cat back exhaust
-Tokico Hp shocks
-Eiboch Sportline springs
-AEM cam gear
-MSD spark plug wires
-Walbro 255 fuel pump
-DC sports front upper strut bar
-B&M fuel pressure regulator
-B&M fuel psi gauge
-Tenzo R Pasion 5 17" white
-Hankooks ventus hr2 tires
-eclipse and mtx speakers
-Alpine CDA-7893
-Alpine XM radio module
