Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 12-08-2010, 06:40 PM
charles thompson charles thompson is offline
2000 impala 3.4eng code P0405
hello new to this site like to say hello. my problem is the egr. the manuel says you can check the voltage at the plug of the egr. i did but the pin that should have 12volts only has 1volt but the pin that should have 5volts does. could this be the problem our is the egr shot ?
Old 12-08-2010, 07:12 PM
danielsatur danielsatur is offline
Re: 2000 impala 3.4eng code P0405
P0405 - indicates a problem with the EGR system.
Suspect-
EGR Valve
Cleaning EGR valve + EGR gase passages.
Check connections going to the EGR valve.
2000 Impala 3.4l Supercharged jayqueezy Impala | Impala SS 10 02-25-2023 12:16 PM
2000 Impala 3.4 - Transmission Problem? JohnT396 Impala | Impala SS 15 10-09-2011 10:40 PM
2000 Venture Code P0405 & P0742 doublecheck Venture 1 05-27-2010 10:06 PM
2005 impala 3.4 code P0507 for IAC or posible vaccum leak HUSTLEMANLV Impala | Impala SS 0 11-16-2009 10:58 PM
Front o2 Sensor Location 2000 Impala 3.8 legotech7 Impala | Impala SS 2 08-28-2009 12:55 PM
