Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 12-07-2010, 05:14 PM
Kid_Buick_98&84's Avatar
Kid_Buick_98&84 Kid_Buick_98&84 is offline
Send a message via MSN to Kid_Buick_98&84 Send a message via Yahoo to Kid_Buick_98&84 Send a message via Skype™ to Kid_Buick_98&84
Angry '92 Can Of Worms...HELP PLEASE
Alright, I piced up this 92 bonne se 3800 about a month ago for cheap so i figured i would have to do some work to it...i was not let down there...when i first got it it would start but kind of rough then smooth out and would run and drive great...now for the issues
when it got colder (and was stil starting) i would have to wait for it to warm up or rev the engine a few times to get it to kick into gear, other wise you would shift into gear and nothing would happen.
Now the thing is not starting, after cranking it once in a while it will hiss a puff of something out of the ends of a rubber connector ontop of the throttle bode. and the area around this is wet with what smells like gas. what would this be? it will crank over but not catch. and it just happened. it was starting then then next day this.
any and all help will be greatly appreciated this car is getting to me haha
Fuel For The Soul
- The Red Dragon
2005 Pontiac Grand Am
- The Beast
1987 GMC Rally STX G2500
R.I.P. Pontiac 1926-2010
You Will Be Forever Missed, And Never Forgotten.
Check it out at my Cardomain Page below
http://www.cardomain.com/ride/2176213
Old 12-07-2010, 07:32 PM
maxwedge maxwedge is online now
A990 racer
Re: '92 Can Of Worms...HELP PLEASE
First check for spark, just basics, no?
Old 12-08-2010, 05:21 AM
Whats the best way to do that in a car? ive done it on a fourwheeler by taking out the 2 plugs and crankin it over, would i just take out one? or what?
Fuel For The Soul
- The Red Dragon
- The Beast
Old 12-08-2010, 07:28 AM
A990 racer
Stick a screw driver in the plug wire, hold it 1/4" from ground, crank it over, should be a sharp blue spark.
Old 12-30-2010, 10:12 AM
UPDATE.
I replaced the coil packs and it fires right up instantly but once it idles down it starts getting a chuggin , very similar to the sound an old v8 muscle car will make. is this the timing?
Fuel For The Soul
- The Red Dragon
- The Beast
Old 04-01-2011, 04:00 PM
savagecowboy_69 savagecowboy_69 is offline
what if anything have you replaced on the car. is it sucking in at the tail pipe have you done a compression test, we need more info
Old 12-26-2011, 08:21 AM
I have gotten this bonny running great now, new coil pack, plugs, wires, starter, fuel pressure regulator and adjusted the timing.
It fires right up every time and runns great now. thanks to those of you that helped! I appreciate it.
Fuel For The Soul
- The Red Dragon
- The Beast
Old 12-26-2011, 09:11 AM
Tech II Tech II is offline
Be interested to know how you "adjusted" the timing....
As for the tranny, sounds like the seals are "hardened".....maybe a transmission service + some Lucas tranny treatment might help.....
Old 12-27-2011, 06:23 PM
Jrs3800 Jrs3800 is offline
Was wondering the same thing.... How do you adjust the timing on a DIS system?
Old 12-27-2011, 07:43 PM
A990 racer
Lightbulb Re: '92 Can Of Worms...HELP PLEASE
We all know this can't be done.
Old 12-29-2011, 02:48 PM
u might want to check the MAF sensor if it aint clean or isnt doing a proper self clean it can screw with ur shifting and how well the car runs. it will make u think u have a fuel/ignition problem and a trans prob at the same time
1996 SKYLARK can anyone HELP PLEASE? crazyoldergirlie Skylark 0 09-22-2005 04:33 PM
fuel problem can someone help please shetaz76 Camaro Discussions 6 08-30-2005 10:47 PM
can some1 help please HEC '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 11-05-2003 10:42 PM
