Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-07-2010, 10:35 AM
wilkerson3 wilkerson3 is offline
Engine Won't Start '99 Suburban
The other night we were working on a '99 Suburban and had it running to help keep warm. While it was idling it started to run rough, so we assumed it needed gas. Put gas in tank and attempted to start again and now it won't start.
Have checked the (don't know the name) spider intake regulator and fuel is shooting from all 8 lines, fuel pressure is 62 at crank and 50 at rest, changed spark plugs and wires. We've dropped fuel in butterfly and it back fires. (Read on the forum that if fuel is dropped in butterfly and starts then it's not a fuel, but an electrical issue. What would the backfire mean?)
So...our next move was to replace dist cap. Any other suggestions of what to test/check or replace? We're trying to determine what would cause it to start running rough when idling. Anyway to check the timing chain or does it just need replaced?
Thanks for any suggestions.
Old 12-07-2010, 10:43 AM
maxwedge maxwedge is offline
A990 racer
Re: Engine Won't Start '99 Suburban
Got good strong blue spark at the plugs? Also the dist gears were known for failing, which would knock out the ign timing.
Old 12-07-2010, 08:00 PM
wardriver wardriver is offline
Does it turn over at all?
If not smack the starter with a hammer then try to start it, that worked for my 99.
Needed to replace the starter.
Old 12-08-2010, 04:41 PM
Chasing down the problem we overlooked replacing the distributor cap. Started right up.
Old 12-08-2010, 05:16 PM
usamarshal usamarshal is offline
haha...glad shes up and running.
Old 12-08-2010, 05:25 PM
j cAT j cAT is offline
as mentioned the distributor on these old high mileage 5.7L engines has bearing wear causing rotor /cap problems ...make sure the distributor shaft it tight ..
2002 Suburban - Motor Swap - Won't Start mrharris32 Suburban 5 09-22-2010 06:48 PM
2002 Chevy Suburban cranks, won't start adamj_rogers Suburban 1 06-17-2010 07:34 AM
99 Saturn SL Won't Start! turtleisland SC/SL/SW 5 08-13-2009 09:52 PM
'99 Yukon misfires and won't start ZippyCT Yukon 10 05-29-2009 08:46 PM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
