Old 12-06-2010, 06:48 PM
viggy58 viggy58 is offline
steering / suspension issues...
so i've read the thread on steering slop, but i think my issue might be more complex.
when driving straight down the road, if i let go of the wheel, it kinda "tick-tocks" left and right, about 1-2 inches each direction. Around turns, it's almost like the wheel is "clicking" back to center, with a good bit of play going into the turn.
i'm also getting a good bit of creaking from the drivers side.
AND i'm losing a bit of power steering fluid from the steering box.
if i pop the hood and grab the intermediate shaft, it has a litle up/down and sise/side play in it. not much, but def seems loose.
in all fairness, i'm at 150k and i've never replaced a single steering / suspension component.
any ideas where i should start? i haven't jacked up the car to really check the tightness of any bolts.
sorry, should have put this in "problem diagnosis...i know better :-)
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 12-09-2010, 05:41 PM
old_master's Avatar
Advisor/Moderator
Re: steering / suspension issues...
Might be a good idea to check the following for looseness and/or play:
Both upper and both lower ball joints
Both inner and both outer tie rod ends
Center link
Idler arm
Pitman arm
Steering gear box
Intermediate steering shaft & rag joint
Both upper and both lower control arm bushings
Both front wheel bearing/hub assemblies
Both sway bar bushings
Both sway bar end links
Any looseness or play in any one of these items can cause handling and/or tire wear issues. After repairs are completed, have an alignment shop check, and adjust if necessary, the front chassis ride height and wheel alignment.
You have to know how it works,
to figure out why it doesn't.
Old 02-28-2011, 01:23 AM
random update:
realized (while working on my sister's 97 sunfire) that my front drivers side tire had a bulge in the tread. the belt had separated. looking at the width of the tire, about a third was raised up a quarter inch above the rest, over about half of the tire. I guess i'm lucky it didn't blow out on me.
put my matching spare on, and all problems went away. nice smooth ride is back!
2001 Chevy Blazer
4.3L 5 speed manual
145k miles
146k miles
Jimmy Steering/Suspension Dan W Jimmy 1 04-04-2006 05:43 PM
Steering/suspension delima impulsive78 S-10 15 02-13-2005 05:18 PM
steering/ suspension acting strange Racincc85 Engineering/ Technical 12 09-23-2004 07:49 PM
