Old 12-06-2010, 05:44 PM
paddyjoe paddyjoe is offline
2001 chevy blazer starting problems
I'm ready to scream! I have just spent $168 replacing my mass air flow connector because the computer read out said it was bad but it did not fix my starting problem. I have this problem when the weather starts to get colder. Sometimes it starts right up and some times it doesn't. It cranks and sounds like it is going to start but then doesn't. I had the fuel pump replaced about 5 years ago. I just had the manifold gasket replaced. I bought a new battery but that did not fix the problem. Does a blazer have a choke?
Thanks
Old 12-06-2010, 09:54 PM
Jerry80871852 Jerry80871852 is offline
Re: 2001 chevy blazer starting problems
Thanks
Might be like mine, replace fuel pump in 05 and just a few weeks ago at when cold it would not start unless I used starting fluid. Sure enough, fuel pump was not holding enough pressure, changed it, fixed problem. Only way to check it is with a fuel pressure gauge.
Have a great day,
Jerry
1992 Chevy S-10 Blazer
4 X 4, 4.3 W engine 3.42 gears
172,000 & still going
Sold
2010 Toyota Tacoma Double Cab 4X4 V6
4.0 V6 DOHC 24V VVT-i 236HP Engine
12,000 plus miles
Bought 10-22-11-2001 Toyota Camry LE SuperWhite 4 Door sedan I-4 89,680 miles
Old 12-07-2010, 02:23 AM
viggy58 viggy58 is offline
if it is cold, and below the dew point, you can almost bet on the distributor cap being bad. especially if it's a duralast from autozone. they usually last about a year. happened to me last winter.
funny you ask about the choke. when mine started screwing up, i would take the intake off the throttle body and choke it while someone turned the key. in reality, it was just a matter of cranking it enough to dry the cap out, and it wopuld start. new dist cap fixed it right away. no probs since.
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
1999 chevy blazer start problems croses4 Problem Diagnosis 8 11-06-2008 07:10 AM
2001 Chevy Blazer - noise when starting esp. when cold and other question dherzog79 Problem Diagnosis 7 04-25-2007 02:18 PM
2001 Chevy Blazer 4X4 problem missileer Blazer 20 01-24-2007 08:31 PM
2000 Chevy Blazer starting Problems ovek714 Blazer 2 07-04-2006 10:21 PM
