Old 05-22-2003, 10:01 PM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
High Idle
In the morning, when the car is cold, I start it up and it revs up to 2 grand steady untill it warms up, then it rests about 1 1/4 grand, my throttle adjustment is a low as it can go...I never used to have this problem before. Anyone got any ideas? BTW I live in florida, so it can even be hot as hell outside, just as long as the motor has been sitting for a long time.
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 05-22-2003, 10:03 PM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
Let me ask a stupid question. When its revving high, if you pop the hood does the idle lower?
Also whens the last time youve given the car a complete rework (plugs, wires, new oil, blah blah blah) ??
AF's Official Asshole
RIP AUNIE
Old 05-22-2003, 10:13 PM
quiXilver's Avatar
Open the hood, nothing changes, but I changed my oil like 5 days ago, so it ain't that, but, the wires have never been replaced since i had it which was back in october, and the plugs around 4-5 months ago.
B18A
Old 05-22-2003, 10:17 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Try adjusting your throttle cable.
Rufes1's Avatar
Rufes1 Rufes1 is offline
Send a message via ICQ to Rufes1
Re: High Idle
Mine is tuned to do that. When I start it up cold it revs really high then one it gets to a warm temp it resets back to low idle.
Just helps it warm up beter.
Old 05-22-2003, 10:20 PM
quiXilver's Avatar
Throttle cable doesn't need to be adjusted...
B18A
Old 05-22-2003, 10:24 PM
mellowboy's Avatar
Well whatelse could it be then? Double check it. Thats what i did to mine.
Old 05-22-2003, 10:33 PM
quiXilver's Avatar
If i loosen it, it won't do anything, the "butterfly" or whatever- is all the way closed...
B18A
Old 05-22-2003, 11:45 PM
cyberfelon's Avatar
cyberfelon cyberfelon is offline
Send a message via AIM to cyberfelon
how are your vacuum lines (connect from intake manifold to back of engine) ive heard cracked lines can cause a higher idle, i dont know if its true or not, but worth a look
Id rather be drifting...
Old 05-23-2003, 01:31 AM
BullShifter's Avatar
when cold idle should be between 1,000-2,000rpm.
(warm)idle speed should be 625rpm +/-50rpm 1.5L, 550rpm +/-50rpm 1.6L with no load - no fan, lights, radio, etc.
adjust the idle by turning the idle adjusting screw not by the throttle cable. there should be a little play in the throttle cable. mine is as tight as it will go with out messing with the idle that i adjusted with the idle adjusting screw
check all of the vacuum hoses aslo
Did you idle go down if you open the hood, HAHA check the blinker fluid & make sure those muffler bearings are lubed:bandit:
Old 05-23-2003, 07:41 AM
quiXilver's Avatar
maybe you should read the other replies before your own
but yea, i wouldn't doubt one of my vaccum lines ain't on all that way or cracked or somethin
B18A
Old 05-23-2003, 08:37 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
I had this problem with my SiR. The fast idle valve is stuffed. On the B16A it is located on the block under the intake manifold. Replace it and you should see a difference. The SiR would idle at 1600 and cold idle at 2800 - not good. Replacing it solved part of the problem, but I also had to replace the throttle body as the Throttle Position Sensor (TPS) had been tampered with and you can't reset them outside of the factory.
You might like to give it a go - no promises, but I had the exact same problem and fixed it this way
Cheers
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 05-23-2003, 10:17 AM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Dang. And I was just going to recommend turning on the A/C.
Flunky
Old 05-23-2003, 12:10 PM
quiXilver's Avatar
Flunky
One question, why the hell would i turn on the AC? That's like if you hear a nasty clunking noise under the hood, just turn the radio up. :finger:
B18A
Old 05-23-2003, 12:32 PM
91civicDXdude's Avatar
usually a cracked vacuum hose will make a vacuum leak, which in turn will cause the idle to bounce up and down from about 1000-1500 rpm. Im with setanta.
