Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-06-2010, 01:47 AM
mazakman51 mazakman51 is offline
Question High engine knock 1999 g cherokee
I have a 1999 4.7 grand cherokee with 181000 miles. Started hearing knock in engine 2 weeks ago. It sounds louder on passenger side and higher towards head rather than lower around crank. The sound hasn't gotten any worse. I don't have much experience with sohc engines. Could this sound have anything to do with the valve train or is it just wishful thinking that it is'nt a rod?
Old 12-07-2010, 08:27 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: High engine knock 1999 g cherokee
An engine bearing would be a deeper klok klok klok from lower down, so from your description it sounds like valvetrain noise.
Has the temperature in your area suddenly gone colder in the last 2 weeks? What grade of motor oil are you using? A heavier oil in colder temps can cause valvetrain noise.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 12-08-2010, 02:13 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Early model 4.7s had a problem with the upper cylinder heads clogging up and destroying the cam bearings and/or camshaft(s). You won't really know what the condition of the engine is until you pull off a valve cover. If you see sludge, you'll need new heads.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 12-08-2010, 06:51 PM
danielsatur danielsatur is offline
Do a compression test on all cylinders on suspected Bank.
1988 cherokee 4.0L hgih idle/engine tick pstoric83 Cherokee 9 08-06-2009 12:18 AM
cherokee high rpm knock- only in acceleration ratrod51 Cherokee 0 09-29-2007 01:09 AM
1992 Cherokee, Engine knock jimr66 Cherokee 2 05-24-2007 07:14 PM
1999 Cherokee - Check Gauges/High Temp Prob glockman1 Cherokee 3 08-29-2005 07:15 AM
High Octane fixed My Engine Knock :-) solaris=amazing Thunderbird 1 07-10-2004 04:10 AM
