Old 12-04-2010, 08:34 PM
davlys davlys is offline
2000 2.4 - rough idle
2000 Grand Am, 2.4 DOHC, 205k miles.
This is an update to my 11-29 post because I think that the problem has become clearer after making some repair attempts. Earlier I reported that the car would stall at stop lights after it warmed up. Since then I have done the following:
Installed new plugs, installed a new air filter, cleaned the idle air control valve, removed and cleaned the throttle body and replaced the mounting gasket, cleaned the inside of the air/oil separator hose (comes from the timing chain cover), cleaned the hose that comes from the bottom of the resonator, changed the oil, added head gasket sealer (Bars-Leak), had the ignition control module checked at Autozone (good) and replaced the coils.
After all of that, it usually does not stall at lights and my rpms stay constant at 600 when stopped, but the idle is so rough that it can cause a stall infrequently. So I have come to the conclusion that the problem is a rough idle. I used to have a weak rough idle and now I have a strong rough idle. Also, the car idles very smoothly at high idle when cold.
Still on my list: Have the fuel filter changed.
I will appreciate any other suggestions.
Thanks.
Old 12-04-2010, 08:41 PM
thephantom1492 thephantom1492 is offline
Re: 2000 2.4 - rough idle
I'ld still suspect a bad IAC valve. Could be damaged.
Old 12-04-2010, 08:59 PM
muff34 muff34 is offline
See how it is after you change your f filter. its cheaper than an IAC and something that should be done with routine maintanance anyway.
Life Is A Highway ,Enjoy The Ride
Old 12-05-2010, 09:27 AM
Blue Bowtie's Avatar
Registered Offender
The only task of the IAC is to deliver air to the intake in whatever volume is required to maintain the target idle RPM. The air is distributed equally to all cylinders via the plenum. It cannot deliver more or less air to any individual cylinder, therefore cannot affect how an individual cylinder fires.
If the engine is maintaining its target curb idle RPM of 600, the IAC is working. If the idle is rough it is due to one or more cylinders firing differently, this is not the fault of the IAC, but more likely incorrect fuel delivery to one cylinder, weak compression in one cylinder, or weak ignition in one cylinder.
Help with 97 Villager rough idle dscott1838 Villager 12 05-09-2009 09:34 AM
Rough Idle Mayathebee Cougar 1 03-22-2009 08:23 PM
Nissan Quest V6 to 2.4 ltr 4 cylinder swap Scraped Knuckles Quest | Presage | Serena 4 02-20-2009 08:59 AM
98 Malibu 2.4 rough idle ri01rod2 Malibu 5 09-24-2007 09:17 AM
2000 Cavalier Z24 2.4L rough idle in park maxemum Cavalier 2 06-02-2006 09:28 PM
