Old 12-04-2010, 04:23 PM
lazeit lazeit is offline
99 Windstar Knocking
The WS has 137 k on it and has an intermittent knocking noise that I have isolated to what I believe is an idler pulley just below the powersterring pump. Has anyone experienced this and or replaced? If so what involved to replace?
Old 12-04-2010, 04:43 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: 99 Windstar Knocking
You can make sure the noise is coming from a serpentine driven accesory by taking the drivebelt off and running the engine for no more than 60 seconds (thanks to wiswind for the tip) if the noise goes away you have a bad pulley, if it doesn't you'll need to make further inspection.
About replacing the pulley, you need to take the drivebelt off, do it from underside the vehicle and with the wheels turned all the way to the right, use a socket and a ratchet to push the tensioner arm and relief the tension on the drivebelt, now take it out.
Use the socket and ratchet to remove the bolt holding the pulley to the tensioner arm, these are left-threaded so make sure you're not over-thigten it.
Also check the idler pulley.
Best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 12-06-2010, 05:08 PM
So after trying to take of just the pulley and replace it..it apears Ford didn't leave enought room to get the bolt out of the hole beacuse of the subframe. I'm think of cuttinging it with a torch and putting a slighty smaller bolt in... Thoughts?
Old 12-06-2010, 05:14 PM
wiswind wiswind is offline
Is this the idler pulley or the tensioner pulley?
I had a '96, so I don't know how the '99 is laid out.
The tensioner pulley on my '96 did not have enough room to clear, so I had to remove the whole tensioner assembly to get the pulley bolt out.
I DID have enough room for the Idler pulley to clear.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 12-06-2010, 05:47 PM
I can get niether of them out becuse of no clerance. Argh
Old 12-06-2010, 06:22 PM
olopezm's Avatar
I did both without removing/cutting anything, just play a little with the bolt. Trust me they do come out with a bit of patience. Took about 30 minutes to replace both; just lean them sideways a bit, to do the tensioner pulley after you have unscrewed the bolt pull the pulley so it rests on the bolt, now lean both towards the front and they will come out.
Best regards,
Oscar.
Old 12-07-2010, 08:02 PM
Good fix..Thanks for your input
1999 3.8L Windstar knock/ratrle under load LTDzak Windstar 4 09-04-2008 07:48 PM
2001 Windstar knocking jkeaton Windstar 15 12-20-2005 02:19 PM
99 Windstar knocks when compressor runs jmhof Windstar 5 07-04-2005 08:12 PM
2000 Windstar Knock ?? oncehadamustang Windstar 9 02-20-2005 08:50 AM
