Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 12-04-2010, 02:13 PM
stanbell stanbell is offline
Exclamation 2000 explorer rough idel at start up
I have had this problem before. I replace the IAC unit and it solved my ploblem then. This time I replaced the IAC unit and it still dies when it is first started. I can keep it running at about 2000 rpms but it wants to fluctuate even with a stead feed of fuel. It runs fine after about two minutes or after I take it for a quick drive around the block. After it warms up and for the rest of the day it starts just fine. I need help, any ideas or suggestions would be appreciated?
Old 12-04-2010, 02:26 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 2000 explorer rough idel at start up
Which engine does your Explorer have (V8, V6 OHV, V6 SOHC)? Have you checked for vacuum leaks, including the PCV elbow and the intake manifold, which are pretty common issues on the V6? When's the last time a tune up was performed, including fuel filter?
-Rod
2000 ford explore Misfire with NO CHECK LIGHT? The_last_regulator Explorer | Explorer Sport Trac 15 09-14-2010 11:50 PM
89 Mustang LX, rough idle and runs terrible. Ericdano Mustang Problem Diagnosis 2 11-07-2009 02:14 AM
Hard Start...Lifters knockin after start-up for like 2 min. 2000 Chevy Silverado 5.3L Silverado_Dude Silverado 8 08-21-2009 07:28 PM
2000 Explorer SOHC No Start Hoppy2 Explorer | Explorer Sport Trac 8 11-27-2008 04:40 PM
2000 explorer xlt wont start unless i hold the gas wide open tacoma man. Explorer | Explorer Sport Trac 2 06-01-2004 10:52 PM
