Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-04-2010, 11:50 AM
2Sluggos 2Sluggos is offline
po171 & po174
I have a 2003 suburban 5.3 and I'm getting bad mileage and po171 and po174 codes. (bank 1 & bank 2 is lean) any ideas? MAF sensor was replaced 2 months ago.
Old 12-04-2010, 02:32 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: po171 & po174
Start with a good fuel pressure check.
Also fuel filter.
Any vacumn leaks or sucking air any place?
Post back fuel pressure readings.
How many miles and last good tune up?
Any other codes or engine missfires?
Has codes been cleared and see what returns?
MT
Old 12-04-2010, 08:59 PM
j cAT j cAT is offline
Re: po171 & po174
fuel pressure should be 53-62psi. the fuel filters need replacing around 30-40,ooomi..usually this fuel pressure issue , would cause poor/slow start...
both banks lean gets into intake leaks,vacuum lines,air ducting from maf to the throttle body leaking...
If you use an oil on your air filter , this may need the MAF cleaned , with MAF CRC MAF CLEANER.
intake gaskets are a very common problem...I use propane to find intake leaks. small torch with a rubber hose connected the the end..with gas turned on very low probe gasket areas for a rpm rise..
the idle air control will drop idle so with too much propane you can make this test for a leak harder , as the IAC will inhibit rpm rise..
what is your idle in drive/neutral ? should be 600-650 rpm...
if higher this would be vacuum leak[s]..
Old 12-08-2010, 08:32 AM
usamarshal usamarshal is offline
Re: po171 & po174
Are you losing any coolant?
Codes PO171 & PO174 1999 Ford Explorer Alvin49tx Explorer | Explorer Sport Trac 9 11-14-2009 09:22 PM
'98 with PO171 and PO174 Fordina Windstar 2 01-28-2007 08:21 PM
1999 po171 and po174 sb68 Windstar 21 04-02-2006 10:00 AM
99 Explorer codes PO171 & PO174 Alvin49tx Explorer | Explorer Sport Trac 0 12-25-2005 03:50 AM
1998 Windstar 3.0 with PO171 & PO174 jgbmo Windstar 15 12-09-2004 09:16 PM
