Old 12-04-2010, 10:29 AM
scoffee scoffee is offline
OBD II codes P0161 and P0141 for O2 sensors
I have a 2001 silverado 5.3. I am getting these codes on the scanner which is some kind of circuit issue. What I'm looking for is a wiring diagram showing which wires are which on the engine side the plug.
Old 12-04-2010, 02:05 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: OBD II codes P0161 and P0141 for O2 sensors
A factory repair manual or a All Data Diy sub is the way to go for a wiring diagram.
There is two fuses for 02 sensors under hood fuse box.
Check both for 12 volts both side.
Pink wire at 02 sensors is heater 12 volt power wire.
black is ground.
Which 02 sensors Delphi or Denso?
MT
Old 12-04-2010, 03:34 PM
j cAT j cAT is offline
this means that the O2 B 15amp fuse is blown !
before replacing this fuse make sure those down stream O2 sensors on each side of the engiine do not have damaged wires...I suspect they are damaged....
Old 12-05-2010, 06:59 AM
Good deal I will try this today. It is a bousch O2 sensor. Thanks for the advice.
What features are important for OBD code readers, and what are not? There's obviously Mithridates Taurus | Taurus Wagon 9 03-13-2010 08:24 PM
01 Blazer-code P0155 and P0141 after lower intake gasket changed? mat300z Problem Diagnosis 0 04-10-2008 12:35 PM
Code P0138 and P0141 Bills 97 Blazer Blazer 2 02-14-2005 07:49 PM
