Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-02-2010, 09:14 PM
cotterman32 cotterman32 is offline
Unhappy Transmision or Transfercase?
1995 GC Larado all time 4X4 I was driving home the other day and noticed a grinding noise coming from the transmision area. Then I lost all the gears. It was makeing all kinds of whining and grinding noises. There was a bad smell of tranny fluid. I let it sit over night. The next day I was able to move it and get it into the garage. Once it got hot I lost all gears again.
lONG STORY SHORT, I put another transmision in. It ran perfect for 2 days. Today the noises came back also some clunking. I totaly lost reverse. The drive gears work but make alot of noise. If I take overdrive off it seems to help?
Please tell me its my transfer case? Or did I just replase the transmision and didnt have too? I am still smelling a strong transmision fluid smell.
Old 12-03-2010, 03:34 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Transmision or Transfercase?
If you have the 318 V8, you have the NP249 transfer case which is full-time 4WD. It has a notorious problem with the viscous coupler failing inside the transfer case that keeps the drivetrain from binding when the front & rear axles are turning at different speeds. There is a way to convert the 249 to a 242 which is a part-time 4WD unit w/o the viscous coupler used in all the 4.0s. My suggestion, if you can, get your old tranny back because it was probably good and just find another transfer case. If you put a used tranny from a junkyard on your truck, you have no idea what condition it was in when you bought it.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 12-03-2010, 08:24 PM
I just took out the transfer case and took it apart. I cant tell if there is anything wrong inside. How can I tell if the transfer case is bad? I started the jeep and put it in reverse without the T case and I did not hear any noise. If the viscous coupling is bad is it possable it would go into drive and not into reverse?
Old 12-05-2010, 09:50 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
The viscous coupler is a strange beast; I've read threads elsewhere with either the forward or reverse gear not working.
If you've got the TC out, replacing the viscous coupler might be the simplest option. They're usually good for about 90k miles.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 12-07-2010, 03:14 PM
try to find a JGC in a junkyard that still has the powertrain attached and pull the T/C. The viscous coupler costs $1100 from the dealer and is on backorder. Most junkyard T/Cs cost around $250.
Old 12-07-2010, 04:26 PM
Good point....simplest isn't always cheapest. Swap's a great idea.
89 S10 Blazer TransferCase fluid change Hellbilly Blazer 0 10-17-2004 07:26 AM
Transfercases, anyone know bout these? Julioluko Off-Topic 6 10-02-2004 01:22 AM
transfercase for sale 2eyefishclaw Trooper | SLX | Bighorn | Wizard 0 01-24-2004 07:43 PM
transfercase jjkjorgenson Engineering/ Technical 0 01-04-2004 09:43 AM
