Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-02-2010, 09:33 AM
lowside lowside is offline
94 Jeep Grand Cherokee 4.0 Start Up Problems
My Grand Cherokee started acting up this morning. It wont start during cranking but when I step on the gas it will run for 2-3 seconds then shut off like its out gas. When I turn the key I can hear the fuel pump prime but it wont start unless I press the gas pedal.I replaced the fuel pump about a year ago. I was wondering if anyone had any ideas.
Old 12-02-2010, 11:49 AM
jdl jdl is offline
Re: 94 Jeep Grand Cherokee 4.0 Start Up Problems
Use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one. Any applicable mil codes? You may need to clean the throttle-body and check idle air.
Old 12-02-2010, 12:51 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Could be the throttle position sensor. Also, check the regular Cherokee section, there's a "how to" section that may be of help.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 12-02-2010, 09:51 PM
Problem solved!
When I went back to run some tests it would not start at all, nor could I hear the fuel pump priming at this point I was directed to check for trouble codes by keying the ignition switch on/off/on/off/on and there was no check engine light but after a while I had a security light that stayed on. The security light lit in the on position and not flashing, means that there was a loss of communication with pcm and I noticed that the auto climate controls digital display weren't reading out as well. luckily, I was able to find a used one dirt cheap for my Jeep as they have several different types and mine had no identifying numbers on it. After swapping the pcm out it ran a little rough at first because the pcm had to relearn the engine sensor inputs but its fine and the starting problem is gone now.
Thanks for all the input as it was useful, because I really want to keep this Jeep, it has 200,000 miles on it and still starts right up with no hesitation and still runs/drives great, in fact the thing runs like it can easily repeat.
Old 12-02-2010, 10:06 PM
Right on! Nice catch. The PCM rarely goes bad IME.
Oil Pump Drive Shaft Froze Up On A 99 Jeep Grand Cherokee 4.0 lowside Grand Cherokee | Grand Cherokee SRT8 2 05-13-2010 11:16 AM
1997 Jeep Grand Cherokee 4.0 Oil Pressure Sending Unit Replaecment? jackie-boy Grand Cherokee | Grand Cherokee SRT8 2 12-07-2005 05:52 PM
93 Jeep Grand Cherokee 4.0 Crank Position Sensor? v2plus20 Cherokee 4 12-05-2004 09:12 AM
2000 Jeep Grand Cherokee / 4.0 caine95 Grand Cherokee | Grand Cherokee SRT8 0 11-02-2004 09:06 PM
