Old 12-01-2010, 12:39 PM
Zippo of Death Zippo of Death is offline
95 GMC jimmy 4.3l V6 DIES randomly while driving...
I recently started having a problem with my jimmy dying randomly. I initially thought it was the cat that was clogged so I bought a new one. We cut the old one off and it was hollowed out, so we put the new one on. It's still dying. I will be driving and it will start cutting out and then all of aq sudden it dies then, I have to wait 2-30 mins for it to start again. We took it to autozone had them read the codes it threw 6 codes that werent for the vehicle. So, they reset the computer it threw so many codes the reader ran out of memory... Is my truck really that messed up or is it the ECM?
Old 12-01-2010, 03:13 PM
viggy58 viggy58 is offline
Re: 95 GMC jimmy 4.3l V6 DIES randomly while driving...
what codes are being thrown?
a bad ignition control module can make the car die. once it cools off it will restart. most parts store can test the module, but it needs to be warm when testing.
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 12-01-2010, 04:31 PM
Exclamation Re: 95 GMC jimmy 4.3l V6 DIES randomly while driving...
See, that's the thing there were so many codes the reader couldn't save them, so I couldn't get a printout.
Old 12-01-2010, 04:34 PM
old_master's Avatar
Advisor/Moderator
1995 was a "change-over" year for S & T series GM vehicles. Early models used OBD1 and later ones used OBD1.5 The cheapie $300 or $400 code readers that the auto parts stores use, sometimes will not acurately retrieve DTC's on the OBD1.5 systems. Best to have a qualified tech retrieve the DTC's for you, then post them here, in the exact order they were retrieved. Which connector is under the dash?
You have to know how it works,
to figure out why it doesn't.
My 2003 Hyundai Accent GL died randomly while driving on the freeway... Why? sling3r Accent | Verna 1 11-09-2010 12:47 PM
1998 GMC Jimmy 4.3l Stalled out won't start CanukGMC Problem Diagnosis 12 06-12-2010 07:45 AM
'93 GMC Jimmy 4.3L Vin 'W' Running issue mr_stimey Problem Diagnosis 1 01-04-2009 07:29 PM
1993 Gmc Jimmy 4.3L Vtech...last stand? Junky1991 Jimmy 8 05-01-2006 09:04 PM
1993 Gmc Jimmy 4.3L Vtech.....not starting Junky1991 Jimmy 14 02-26-2006 09:52 PM
