Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 12-01-2010, 01:02 AM
tomtom55 tomtom55 is offline
over heating issue?
Okay I have a 99 dodge intrepid. I will drive around 30 miles and turn the car off to eat or something and it will turn back on fine, but after turning the car off and on 1 or 2 more times it doesn't want to start till my car cools down for an hour or so. When this happens I check my water and its full. Someone said it mite be a sensor of somekind, but I'm not sure. Any ideas??
Old 12-01-2010, 11:12 AM
jdl jdl is offline
Re: over heating issue?
Just start with the basics. You can carry a known good spark plug or spark tester in the glove-box, they won't get hot. I didn't check to see if you had coil on plug ignition?
When the problem occurs, if the vehicle cranks good but won't start, pull a spark plug wire, if the wire is hot, use a glove. Place tester in plug boot, ground tester to metal part of engine, engine cranking, watch for spark. You have to test when problem is ongoing. Any applicable trouble codes?
Old 12-01-2010, 02:19 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
you could have a problem with the crankshaft position sensor losing its signal. The sensor sits right near the exhaust on the passenger side mounted on the transmission. There's supposed to be a heat shield around it to keep it from overheating, make sure that's there before going forward. Also check all your ground connections under the hood, make sure they aren't loose or corroded. A faulty ground would cause intermittent problems.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 03-07-2011, 07:43 AM
j43rsr2 j43rsr2 is offline
sometimes when a fuel pump gets ready to go it will do that once it cools off it will start had that happen a few times
Old 05-16-2011, 08:42 AM
stlrj stlrj is offline
Originally Posted by tomtom55 View Post
... but after turning the car off and on 1 or 2 more times it doesn't want to start till my car cools down for an hour or so. Any ideas??
Camshaft position sensor may be bad or out of adjustment ( too far from trigger wheel on cam sprocket). It needs to be barely touching the trigger wheel, a distance of the thickness of a piece of paper.
2000 LS NO POWER TO AC/HEAT controller Cassious Regal 1 12-17-2009 06:29 PM
97 Mystique Over Heats and Causes Tranny Issues shivparekh Mystique 6 01-11-2009 02:51 AM
no heat / over heating dalm8ton Cherokee 4 01-01-2005 06:51 PM
Pls help 88 dodge caravan over heating no heat belvnmajk Caravan | Voyager 2 11-17-2004 12:28 AM
over heating issue badassjorge Monte Carlo 2 07-05-2004 01:36 PM
