Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 11-30-2010, 11:47 AM
thr thr is offline
Loss of power
Hello,
I have a 2006 Panoz GTS LS-1
I am having trouble keeping the car running on the grid and coming off the track. It seems that when the clutch is depressed the car shuts off in idle or slowing down.
Any ideas?
Thanks, Todd
Old 11-30-2010, 06:23 PM
P_Mac P_Mac is offline
Re: Loss of power
I'm sure others more knowledgeable than I will chime in, but my first thought is the flywheel. If you have a lighter flywheel, it spins down more quickly than the ECU might expect it to, and you don't get enough fuel to maintain idle.
Is this behavior new? Have you changed anything else recently?
Old 11-30-2010, 10:17 PM
panozracing's Avatar
panozracing panozracing is offline
Re: Loss of power
My brother had stalling problems in his corvette and went to a heavier clutch and that solved the problem.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 11-30-2010, 11:38 PM
NZGTRA17 NZGTRA17 is offline
Re: Loss of power
Originally Posted by thr View Post
Hello,
Any ideas?
Thanks, Todd
Todd, what happens if you apply some throttle when the clutch is depressed? Will the engine keep running or does it still shut down? Has this fault just appeared or have you made some changes to the engine/trans?
I had a similar'ish problem with my carb'ed car but this was due to fuel slosh under brakes. In a carb'ed car I would be looking for a mixture or timing issue. Another thing to look (longshot) at is that the clutch is not "over stroking" and trying to turn the pressure plate diaphragm inside out. This would put some drag on the engine and could possibly stall it.
Kel.
Kel M
Panoz GTRA #17
New Zealand
Old 12-01-2010, 06:58 AM
thr thr is offline
Re: Loss of power
The problem has been present since I purchased the car earlier this year.
The car has no problem starting right back up, and if enough gas is applied has no problems remaining on. I have been heel/toeing coming off the track and have been able to keep the car on without depressing the clutch. The Weekend is probably a bust for RA. Now obligated for my Mom's Birthday dinner in Buckhead. Will plan on March BMWCCA at RA.
Todd
Old 12-05-2010, 12:19 PM
eric1h eric1h is offline
Re: Loss of power
Can you just bump up the idle screw to keep it running?
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 12-06-2010, 09:22 AM
thr thr is offline
Re: Loss of power
Possibly, worth a try anyway.
Old 12-06-2010, 09:48 PM
Re: Loss of power
Possibly a good tip and simple fix. One thing to watch for with this though may be "running on". Certainly happens with carb race cars if idle bumped higher.
Kel.
Kel M
Panoz GTRA #17
New Zealand
Old 12-07-2010, 11:02 AM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Re: Loss of power
That's all just in the tuning.... it's probably not getting enough air via the IAC valve to keep running. Does the car have a light-weight clutch setup?
The Corvettes are drive-by-wire and you have to adjust the throttle decay rates when you put in a bigger cam or lighten up the rotating mass a bunch.
Not sure how the LS1 Panoz cars are tuned though.... I think they use some sort of MSD computer setup.
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Old 12-07-2010, 03:02 PM
thr thr is offline
Re: Loss of power
Honestly, that sounds right about the valve. I dont know about the clutchj. Great time at RA BTW
Old 12-07-2010, 04:29 PM
Cobra4B's Avatar
Re: Loss of power
Thanks.... was pretty happy for having not been there in over 7 years and never in anything with any power. Finished just out of the "money" both days in 4th place.
See if you can figure out what engine mangement system is used for the LS1 in the Panoz, how to tune it, and then find someone who can tune it.
When I put a big cam in my old yellow Z06 it needed quite a bit of massaging to operate similar to a stock car in traffic, hot start, run with the AC on and catch idle when reving down. The Fidanza aluminum flywheel didn't help.
Before I had the cam and just had the lighter flywheel it'd dip to 500 rpms when coming to a light, then jump up to like 1200 and then catch idle. Once the cam was introduced it was all kinds of messed up, but a good tuner took care of all of it. But I don't think HPTuners will work on the system in the Panoz.
Best of luck. Maybe try calling Penske or Wirewheel? I assume the cars ran properly when they had them... wonder what could have changed? Maybe a sensor is messing up? Does it still use a throttle position sensor?
Brian B.
Old 12-09-2010, 02:33 PM
thr thr is offline
Re: Loss of power
My family is from Franklin, Va.
Anyway, would love to try VIR someday. Thanks for the advice. I have a pretty good mechanic. I will give him the recommendations. BTW, I talked to another person who has the same car and he has the same problem.
Todd
2003 Sienna Gummed Engine, Power Loss, Clicking Nebeno Sienna 3 07-17-2010 07:05 PM
power steering problem in the rain eu0688 Impala | Impala SS 2 12-13-2009 11:23 PM
Power Loss in an '89 4Runner toyotatech89 4Runner/GX470 6 08-07-2009 01:23 PM
97 7.3 power not what i used to be 86troopercrzy E Series 2 03-21-2009 11:03 AM
9-5 loss-of-power and loss-of-brakes kenles 9-5 3 09-12-2005 09:31 AM
