Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 11-29-2010, 12:33 PM
crazyduetoiowa crazyduetoiowa is offline
Send a message via AIM to crazyduetoiowa Send a message via Yahoo to crazyduetoiowa
starting issue
I have an 01 3.8ltr with 136k. It recently requires you to start it twice. The first time it starts and promptly dies. Second start it keeps running. OR it will start on one try and bog down quickly and then run normal. Where should I begin my problem solving?
Thanks,
Derek
Old 11-29-2010, 06:04 PM
j cAT j cAT is offline
Re: starting issue
Thanks,
Derek
replace fuel filter every 30,ooomi ????
then check fuel pressure if still n/g
Old 11-29-2010, 06:29 PM
danielsatur danielsatur is offline
Re: starting issue
Also replace Air filter, and clean the MAF sensor with CRC electronic, or CRC MAF sensor cleaner.
Old 11-30-2010, 12:37 PM
Re: starting issue
Hello, we bought the car this summer so I have no clue when the fuel filter was replaced. Where is it located on this model of car? I know I put a new air filter in but have done nothing with MAF.
Thanks for the ideas!
Old 11-30-2010, 04:29 PM
Re: starting issue
fuel filter is under the rear of the vehicle next to the fuel tank.
GM says to replace this filter when the engine has starting issues..I found 30,ooomi is the correct time to avoid damage / getting stuck ..
96 S10 Ignition/Starting Issue fmhsgrad96 Problem Diagnosis 5 05-25-2012 08:19 PM
Grand AM 96 3100 V6 Starting Issues Alfredogalvan Grand AM 6 11-13-2009 09:40 PM
Rx7 turbo issue/starting issue/all kinds of stuff...any advice is appreciated neffsrx7 RX-7 2 09-03-2009 02:25 PM
93 Lincoln Town Car - Cold Start and Cold Run Issues blogsdon Town Car 1 08-14-2009 12:00 PM
1990 F150 starting issue - key start position problem, and jumping with solenoid mounddog F Series 2 08-20-2008 02:10 AM
