Old 11-28-2010, 06:15 PM
rtobrian rtobrian is offline
02 Grand Am bad fuel pump?
The car ran good until my wife went to leave and it started, ran rough for a second then stalled. I checked fuses, relays, and the security light is not on. I pressed the schrader valve and fuel came out but not much pressure. Whenever I turn the key on I hear no noise or humming. The fuel filter was changed last year. I'm going to see if I can get ahold of a pressure gage and check it but i'm almost certain it's the pump. I think i'm just going to drop the tank and put a new pump in...
Old 11-29-2010, 12:34 AM
thephantom1492 thephantom1492 is offline
Re: 02 Grand Am bad fuel pump?
Try this: bang on the bottom of the tank, there is a chance that it move the pump a bit, causing it to work again.
This would confirm the pump problem...
Old 11-29-2010, 10:02 PM
I took a rubber mallet and banged all over the bottom of the tank but nothing happened. Oh well, I'll figure it out.
Old 12-02-2010, 10:55 PM
I dropped a Delphi pump in the tank and threw a Delco filter on and the car runs like a champ!
Old 12-02-2010, 11:05 PM
danielsatur danielsatur is offline
Was there access for the fuel pump under the rear seat or trunk?
Old 12-03-2010, 03:08 PM
No, I removed the backseat and there's nothing under there. The only thing holding the tank up are the two metal straps. It took about 3hrs.
2000 grand prix noisy fuel pump? xcmhs Grand Prix 1 06-22-2010 11:14 AM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-05-2009 12:39 AM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 03:08 PM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 10:14 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 09:04 AM
