Old 11-28-2010, 04:05 PM
Bert 1974 Bert 1974 is offline
No Fire
I am working on a 1993 S10 4.3Z. I was driving and it shut down as if I turned off the key. I am getting fuel but I have no power out of my coil. Is there any where that I should start looking for my problem?
Old 11-28-2010, 06:07 PM
viggy58 viggy58 is offline
Re: No Fire
start by checking fuses... any voltage at the coil?
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 11-28-2010, 06:14 PM
old_master's Avatar
Advisor/Moderator
Re: No Fire
When you say you have fuel, do the injectors squirt fuel while cranking?
You have to know how it works,
to figure out why it doesn't.
Old 11-28-2010, 10:05 PM
Re: No Fire
I had someone to crank the engine so I could watch the injectors and they were squirting fuel into the tb. I did think to check the fuses and all were good. I checked for fire by using a spark plug in the number one plug wire. I also put the plug in the coil wire and still no fire, not even weak fire.
even-fire or odd-fire engine xrtdx8 Jimmy 5 10-24-2005 04:56 PM
2000 jgc limited --turns over but wont fire-- wait 1 hour then fires!! andybair Grand Cherokee | Grand Cherokee SRT8 0 05-18-2004 09:40 PM
Fire Fire Fire aviator18 Cavalier 1 05-04-2004 02:37 PM
