Go Back   Automotive Forums Car Chat > Volkswagen > GTI
Old 11-28-2010, 01:44 PM
zack9104 zack9104 is offline
OBDII VR6 help!!!!!!
I have a 1996 golf VR6 and I think I am having ground issues. I put a new head one the engine but before i did that I took it completely out. Now it is all put back together. The fuel pump isn't getting consistent power. Also it is only getting one spark. When I hook up the battery the fuel and temp. gauge bounce like crazy and the ABS and low fuel light stay on. I checked all the grounds in the engine bay and on the computer and I cleaned them all and it is still doing this. It started once and ran for a few minutes until i pushed on the throttle and then it died. Has anyone had a problem like this or think they can help it would be greatly appreciated! Thank you!
Old 11-28-2010, 02:27 PM
danielsatur danielsatur is offline
Re: OBDII VR6 help!!!!!!
Was there a ground wire from the fire wall to the head?
Old 11-28-2010, 02:47 PM
No there isn't but I hooked a ground from the fire wall to the upper intake manifold and it did the same thing.
Old 11-28-2010, 03:25 PM
Can you turn the lights on, and honk your horn?
Old 11-28-2010, 10:47 PM
yes i can
Old 11-30-2010, 10:28 PM
The fuel pump is probably being turned off @ a certain psi, by the fuel regulator.
The ignition module canbe tested at a local Auto parts store.
Old 03-29-2011, 08:21 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Is the ground from the transmission upper middle bolt connected to the battery? Did you check the ground under the battery tray, its for the cluster abs and ful pump.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 03:27 PM
2001 Jetta GLX VR6 help!! peja43916 '97 - '03 1 05-06-2006 01:59 AM
1995 OBDI or OBDII Confusion??? HELP! BlazerLT Blazer 14 09-19-2005 01:06 PM
99 firebird obdII error help redarm59 Camaro Discussions 0 05-21-2005 07:01 PM
1995 OBDI or OBDII Confusion??? HELP! BlazerLT S-10 8 09-26-2004 03:02 PM
