Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 11-27-2010, 09:57 PM
johnboy123 johnboy123 is offline
1985 Mercury Marquis (not Grand)
Hello, my first post. Here's whats going on..
1985 Mercury Marquis, AT, PB, V-6, TBI. All factory/stock.
This problem has been going on for years, hopefully someone can sleuth this out!
At the first crank of the day (or night) in any weather, the car idles high, I kick it down with the gas pedal, it idles down smooth without surges, or misses. Then when I put it in reverse, it literally slams in gear, then stalls. I restart it again, put it in reverse, and its good for the rest of the running day, no stalling at all. I've been under the hood and dash, no leaks, no check engine light, no white or dark exhaust. The idle is about right in the summer with the AC on. No lagging or pinging during acceleration. Shifts smoothly. (except for the first start episodes). I"ve allowed this car to warm up and drop idle for up to 30 minutes at its lowest idle, still does it, but only once per day!
Old 11-27-2010, 11:31 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 1985 Mercury Marquis (not Grand)
First and foremost, welcome to AF!
I wonder if it is transmission related. I'm not familiar with the Mercury Marquis and the engines/transmissions in 85 but since you only have the problem during the first gear shift, I wonder if it is a locked up torque converter or some other problem that causes too much load on the engine too quickly to cause it to stall?
This may sound counter intuitive, but if you shift into reverse with your left foot holding the brake firmly and your right food slightly on the gas (give it an extra 300 RPMs approximately), does it still stall?
Does this problem only happen when shifting into reverse or does it also happen if you shift into drive first thing in the morning?
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 11-30-2012, 10:22 AM
Joe Bloggs Joe Bloggs is offline
I have an 1985 marquis thats doing the same thing
starts and runs fine but it started slamming into gear and stalling when going from park to reverse or drive.I have found if I can get it rolling it will drive away but will shake and stall if I come to a complete stop like the converter is licked up.
then it wont do that for a day or two then its impossible to drive for a few days
help me please
1985 mercury marquis brougham sniper77 General Discussion 0 06-18-2006 12:13 AM
1985 mercury marquis brougham sniper77 Grand Marquis 0 06-18-2006 12:12 AM
1985 Grand Marquis question colinlesser Grand Marquis 8 01-11-2006 12:34 PM
92 Mercury Marquis running lights on all the time even when car is not running debdenis Grand Marquis 0 02-03-2005 08:30 PM
mercury marquis anti theft system chipper3 Grand Marquis 1 10-27-2004 07:40 PM
