Old 11-27-2010, 08:55 PM
mybad_z71 mybad_z71 is offline
lower ball joint
hello there, whats the easiest way to remove and install a pressed in lower ball joint on my 97 z71 without using a press?
Old 11-27-2010, 10:53 PM
Blue Bowtie's Avatar
Registered Offender
Re: lower ball joint
The easiest way? Hand it to someone who does have a press and drifts. The chamfered hole in the stamped steel lower control arm should not be heated. The only safe method is to press out the old joint and press in the replacement. You can perform the swingarm removal and replacement yourself, and probably will want to replace the swingarm bushings while it's out. This also requires a press and drifts.
Old 11-28-2010, 07:37 PM
guess what? autozone has a tool made just for chevys and gmc. of all things its called "chevy lower ball joint removal tool" go figure huh. it looks like a 12" c-clamp with two different end tools to remove the old one and instal the new one. the hardest part was getting the old ones out. i was done before i knew it. thx for the reply blue.
Old 11-05-2011, 05:04 AM
Smiff 24 Smiff 24 is offline
Has anyone used the Harbor Freight brand tool (c-clamp type)
any issues with it ?
RC car Nut !
Old 11-18-2011, 06:38 PM
broughy84's Avatar
broughy84 broughy84 is offline
I've got one. Works just fine.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
ball joint? tie rod? HELP! cjedstrom Cougar 2 11-26-2009 05:53 PM
Lower ball joint replacement anyone done it? RedRacerCivic '88 - '91 Civic | CRX | Wagon | Shuttlee 5 12-25-2003 10:10 PM
Castle Nut just spins on lower ball joint york2600 Integra 5 05-22-2003 02:41 PM
Worn Lower Ball Joints RAYKENNY Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 3 12-01-2002 08:50 PM
Lower ball joint ales Maintenance 13 03-08-2002 11:40 AM
