Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 11-06-2001, 10:35 PM
jprimera jprimera is offline
does the AAC valve affect the performance when its not working ok?
thanks!!
1998 PRIMERA GX 10.1 CR Chile.
Old 11-07-2001, 06:50 AM
P10DET's Avatar
P10DET P10DET is offline
Most likely, yes. The AAC valve controls your idle by letting small amounts of air into the engine. If it is malfunctioning, in all likelihood, it will be letting unmetered air into the engine off idle. Either that, or it is closed and forcing the ECU to work hard at maintaining a decent idel. This would likely make low end throttle response a bit poor.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 11-07-2001, 06:17 PM
thank you George ,so that means that I have to replaced for a new one ,have to spend 100 dollars ,
When the AAC valve is good,if I disconect the "central"connector,the car would stop right?,my car do not do that,soo I suposed is bad.Anyway Im gona replaced.
Thanks again.
Old 11-07-2001, 09:44 PM
P10DET's Avatar
Thanks again.
Whoa! Wait. You should still be able to disconnect the AAC valve connector and the car should still run. In fact, it's one way folks can get to set the base idle and timing if the ECU doesn't go into "set" mode properly (along with disconnecting the TPS).
I would highly recommend reading the SE-R Mailing List archives. There has been a lot of good information on this topic posted there. I don't remember the details well enough right now.
George Roffe
Houston, Texas USA
00 328i
ICV Idle Control Valve not working squawcrk Cavalier Problem Diagnosis 1 07-03-2010 01:04 PM
The AAC, truck of the future? Dylan_Michael Concepts (AAC) 7 12-13-2001 02:01 PM
