Go Back   Automotive Forums Car Chat > Buick > Century
Old 11-27-2010, 05:31 AM
barker23 barker23 is offline
Send a message via Yahoo to barker23
2001 wheel hub assy install
Getting ready to install both front hub assemblies. Anything special I need to be aware of?
03 Chevy Trailblazer LT EXT
04 Silverado Z71
88 Fiero Formula V-6
82 Chevy Corvette
07 Dodge Caliber
Old 11-27-2010, 08:10 AM
jrecken jrecken is offline
Re: 2001 wheel hub assy install
It was a pretty easy job. The only cautions I can think of is be careful with the wires and clean the parts when putting everything back together. Use quality parts, I have heard that the cheap ones only last about a year.
good luck.
Old 11-27-2010, 08:37 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
the hardest part will be getting the old hubs out. They corrode into the spindle and can be a real bear to get out, especially if you let the bad ones go until they got hot. DO NOT use an air impact gun on the axle nut when installing the new hubs, or you can almost guarantee damaging the ABS sensors. Torque the axle nut to spec with a hand torque wrench, as the torque preloads the bearing to insure it doesn't come apart or get overtightened. Follow any new torque specs that come with your replacement bearings if they differ from a repair manual spec, as slight variations in design may require a revised torque setting.
One last thing, your year is a changeover year so be sure you get the proper hubs. Early '01's have a stainless steel clip that holds the abs wiring out of the way, where the late '01's have a plastic clip. The brackets are different, and the wrong style clip will not attach securely, which in turn can ruin the new bearings. Good luck!
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 11-27-2010, 08:53 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Visit our Buick Tips & Maintenance subforum. See link below for hub R&R procedure.
Click here
Timeslip 08/12/06
AF Community Guidelines
04 Cavy Wheel Hub Sensor atlas86 Cavalier Problem Diagnosis 0 09-08-2009 11:46 PM
93 JGC wheel bearing/hub assy rob87035 Grand Cherokee | Grand Cherokee SRT8 1 02-25-2007 11:31 AM
Installing front wheel hub [IN PROGRESS] 5/25/06 6PM Langning Grand Prix 14 06-13-2006 03:30 PM
92 325i rear wheel hub assembly install Leafman 3 Series 0 05-18-2005 09:15 AM
Removing wheel/speed sensor from Hub Assy bwhuot2 Galant 0 03-26-2005 11:13 PM
