Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 11-26-2010, 05:36 PM
masonm89 masonm89 is offline
lincoln, valve and coil problems and more
Great car however it is very clear there is a problem with these cars that will over 90% of time cost you abou 3-5 grand more over its lifetime. Coil packets will go, they almost always all need to be replaced when one goes, I tried getting around it, its just more time away from your car if you try. Engine light issue, just stays on even though there is no issue. Coolant/heating issue. Your horn will invariably not work. Your windows during the winter will most likley not go up or down. Your tires range from 175 and up for each tire to replace an average about once every 2 years if you drive 80mph and and dont slow around corners much. This car overall, drives nice, looks pretty. But so don't a lot of hookers, and just like a hooker she cost too much too keep. lincoln owner< 6 years- There should a class action lawsuit on cars that have so many issues consitantly like this
Old 11-26-2010, 08:19 PM
ctwright ctwright is offline
Re: lincoln, valve and coil problems and more
What year is this car?, things go bad on all cars after time, especially the problem you have with the power windows in winter time, sometimes things just get worn and need replacing. What is the biggest issue you are having with the car now so someone could help?
Old 12-01-2010, 10:34 AM
gcwimmer gcwimmer is offline
Re: Lincoln, valve and coil problems and more
If your Lincoln LS is a V8 and 2003 to 2005 there is an extended warranty of 10 years/100K miles on the COP, covers gasket, labor, and associated parts, see a dealer. Tires, you get what you pay for. If you get a steady CEL it will throw a code, get it read. My LS is 6 years old + and so far have not experienced your problems except replaced my tires once. The Lincoln LS is a complex performance automobile and requires more maintenance than a Honda, try a BMW or a Audi and see what real maintenance cost is.
2002 Lincoln LS Fuse Block Problem danieljcurrie LS | MKZ 1 03-31-2010 12:50 PM
2002 explorer v8 4wd eb high idle and shifting problem BAKERCONTAINER Explorer | Explorer Sport Trac 0 02-03-2010 01:22 PM
1994 voyager ac and heat problems bitco Caravan | Voyager 2 10-20-2009 08:49 AM
93 Lincoln Town Car - Cold Start and Cold Run Issues blogsdon Town Car 1 08-14-2009 12:00 PM
92 Olds cutlass idle and emissions problems and other awe341max Cutlass Series 5 05-30-2008 08:44 AM
