Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 11-26-2010, 11:52 AM
corollave corollave is offline
Wheels
hey! i am looking to buy a set of steel rims for my 2006 impala. it currently has 16 inch alloy rims on it now. i have found rims that are the proper size but are for a different manufacture. ie pontiac, ford. my question is well they work on the impala?
Old 11-26-2010, 04:46 PM
auto trainy auto trainy is offline
Exclamation Re: Wheels
Caution! Whatever wheel you use make sure it fits tightly on the hub or axle and not be held by the lug nuts alone. Good Luck
Old 11-27-2010, 01:59 AM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: Wheels
Does your new wheels have the same bolt circle pattern and wheel offset as the originals ? As for getting the proper wheels , the lower cost base Impalas came with steel wheels ( and wheel covers - .ie. hubcaps ) so you should be able to find some at a salvage yard for a reasonable cost if the ones you have don't work out . Good luck !
" Sometimes I grow so tired "
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 11:27 AM
Gsr wheels-99-up SI wheels rushb18 COMPLETELY off-topic 7 11-05-2004 11:18 AM
Why do OEM wheels balance better than custom wheels? jberenyi Tires and Wheels 1 10-13-2004 11:04 AM
VIP Wheel re-release info for the wheel people malsheem Car Modeling 11 04-09-2004 06:16 PM
