Old 11-25-2010, 10:54 AM
diem diem is offline
Creaking head bolts while torquing
Is this normal? I'm installing heads on a 3.4 and the outter most short bolts creak and are VERY hard to torque. The inner most turn smooth and torque fine, but do not seem very tight.
Old 11-25-2010, 11:40 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Creaking head bolts while torquing
Are you re-using the original head bolts or new? These are supposed to be TTY.
Timeslip 08/12/06
AF Community Guidelines
Old 11-25-2010, 11:49 AM
Blue Bowtie's Avatar
Registered Offender
Are the threads clean and lubricated? (PST Sealant also lubricates for assembly.)
Old 11-25-2010, 03:20 PM
Yes, they are new bolts. I did not lubricate or use any sealant on them. I actually removed them and purchased another set because I'm not confident they were correct.
I did have the heads resurfaced and wonder if they are bottoming out. It's like they don't want to turn anymore.
Old 11-25-2010, 06:39 PM
maxwedge maxwedge is offline
A990 racer
TTY bolts have an initial torque setting then a torque angle meter is used for the final tightening, also did you compare the old to new lengths, I doubt the heads were resurfaced enough to cause bottoming, but remove a problem bolt measure the depth of the hole and compare it to the length of the bolt.
Old 11-26-2010, 10:47 AM
Correct. When setting the additional 95 degree angle, it began creaking and did not want to turn. I got it turned but it took all I had and I was afraid I was going to snap the bolt. I don't think it should be like that.
I'm going to try measuring them later. I'm also going to try grinding one of the old bolts to act as a thread chaser.
Old 11-26-2010, 08:04 PM
Ha ha
I used an old head bolt and grinded a spot on both sides to clean up the threads. Then used a thread sealant on them to help lubricate. They went in great this time around!
1994 Geo Tracker head bolt torque and valve cover torque KINNEY0201 Tracker 0 10-19-2005 03:54 PM
'92 SC - head gasket - proper head bolt torqueing procedure? kaje71 Thunderbird 1 07-02-2005 11:46 AM
94 camaro, 3.4 head bolt torque zbo2 Camaro Discussions 1 12-20-2003 05:39 PM
Torque settings on Head bolts and cam bolts viclaster Engineering/ Technical 3 05-01-2003 01:01 PM
torque specs on b16 head bolts velocitySiR Engineering/ Technical 0 03-27-2002 10:03 PM
