Old 11-24-2010, 08:14 AM
royals1969 royals1969 is offline
temp not steady
2002 trailblazer LT model with 140K miles..4.2 6cly...there are no codes, but my coolant temp is not steady, it is constantly moving between 210 and 220 back and forth on the guage...i have already changed the water pump and the coolant. Any other ideas? perhaps coolant sensor or themostat? thanks in advance..Bob
Old 11-24-2010, 12:45 PM
maxwedge maxwedge is offline
A990 racer
Re: temp not steady
This could be caused by air in the system or a sticking t'stat, did it do it before the work was done, heater work ok, any other symptoms?
Old 11-25-2010, 08:53 AM
Re: temp not steady
yes, the temp started moving about a month ago before anything was touched. i do get good heat and AC is also fine. There are no other symptoms...i checked the coolant fluid levels both in radiator and overflow and both are at proper levels. I am leaning towards changing both the thermostat and coolant sensor because i have been reading that it can be a bit difficult to get the alternator out to get access to both of these parts, so only want to do it once, and besides parts not too expensive. am i heaqding in the right direction ?
Old 11-25-2010, 12:08 PM
A990 racer
Re: temp not steady
Try bleeding the system first, see what happens.
Idle not steady - moves up/down 150rpm Ralph50 LeSabre 3 12-18-2008 10:46 PM
'92 3300 Smooth Idle, But Not Steady maxman Grand AM 1 01-13-2007 11:12 PM
98 Lesabre engine idle not steady on occasion swipter LeSabre 12 11-21-2004 09:17 PM
1984 635CSi Tach & Temp not working anthonym 6 Series 8 06-10-2004 12:45 PM
2001 blazer auto. locks & temp. not working Mike A Blazer 0 05-25-2004 12:19 PM
