Go Back   Automotive Forums Car Chat > Pontiac > GTO > Classic GTO's (1964-1974)
Old 11-23-2010, 08:39 PM
BurtZ's Avatar
BurtZ BurtZ is offline
Power Steering ??
I would like to convert my 66 GTO from manual to power steering. I need to acquire everything. Any one have one or have any ideas??
Thanx
Old 11-24-2010, 09:02 AM
MrPbody MrPbody is offline
AF -Advisor
Re: Power Steering ??
The steering box from any A-body, '64-'72, or F-body '70-'78, will "fit". The "best" ones come from the '77 and '78 T/As with WS-6 suspension packages. '79-newer are "metric", and can still be adapted, but fasteners are all different, as are the hose fittings. The pump should be calibrated for the steering box used, not "the car". Mounting brackets and pulleys will need to come from a "donor car", but care must be taken to keep all the right "era" components. Water pump and timing cover era are critical. Entire "kits" are available for this, too, through mail-order houses such as Summit or Jeg's. Ames Performance and Performance Years offer the correct pulleys and brackets "new". It CAN be a "bag of worms" to get the pulleys right.Jim
Old 11-24-2010, 12:50 PM
BurtZ's Avatar
This is definitely a can of worms. I am trying to find everything from a 66. Would you happen to know if the system from a 66 - 326 LeMans is the same?
Thanx
Old 11-24-2010, 01:43 PM
AF -Advisor
To the best of my knowledge, yes, the LeMans is the same as GTO for those pieces. Jim
Old 11-24-2010, 10:25 PM
BurtZ's Avatar
I thought the LeMans was a 66. It is actually a 67 - as long as I get all the components will it still work OK?
Thanks again
Old 11-26-2010, 01:53 PM
AF -Advisor
SHOULD be okay...
Jim
Power steering flush Windstar 98 - No place to work serge_saati Windstar 9 11-05-2015 09:02 PM
Problems with Acceleration and now Power Steering dbhynds '01-'05 Civic 5 01-06-2010 08:41 AM
Cutlass Supreme - which power steering fluid serge_saati Cutlass Series 1 12-07-2009 08:15 AM
92 Cutlass Supreme Power Steering Hose Mikey_G Cutlass Series 4 11-23-2009 02:47 PM
2000 PA Power Steering Fluid Check buickultra2000 Park Avenue 2 11-12-2009 11:12 AM
