Old 11-22-2010, 03:13 PM
Ryouice Ryouice is offline
2000 S-10 not cranking
Hi,
I have a 2000 S-10 with the 4 cyl engine. Problem has been going on for awhile now. When I go to start the truck, while key is in the starting position all the electrical (lights, cd player, dash lights) come on but the truck wont turn over. For a little while if I kept turning the key off then trying to start it it would eventually turn over and start. Now it wont even start no matter what I do.
Old 11-23-2010, 07:11 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2000 S-10 not cranking
Originally Posted by Ryouice View Post
Hi,
First thing to check is for good charged battery and good cables.
Then check starter.
Find purple start wire to starter solenoid and put 12 volt jumper on it and see if starter will crank.
If not repair starter or solenoid or positive battery cable to it.
If it cranks with good 12 volts to purple wire to solenoid.
Get a wiring diagram of the starter circuit and a 12 volt test light.
The starter circuit starts at ign switch to crank fuse and then neutral safety switch/automatic or clutch pedal switch standard transmission.
Then to starter relay in under hood fuse box.
Then from relay to starter solenoid on purple wire to starter solenoid.
Let us know what these test show.
MT
Help! my 2000 S-10 Is having trouble starting.. hhendricks1989 Problem Diagnosis 3 09-20-2010 01:33 AM
2000 Ford Windstar, Not a whole lot of knowledge cshawn Windstar 8 08-14-2010 05:40 PM
2000 S-10 4.3L V6 AC Replacement Questions TallyMatt S-10 11 07-11-2009 07:30 PM
97 S-10 Will not crank jasbri Problem Diagnosis 1 02-08-2008 02:35 PM
S-10 stalls then will not crank at first Opiedog S-10 0 07-09-2004 11:25 PM
