Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 11-21-2010, 04:31 PM
notimprezed notimprezed is offline
p0410-air pump
My 2004 I6 Envoy's SES light came on and the code comes up p0410. From what I've seen this means a bad air pump, which is about a $225 part. Do you guys think thats accurate? Is this a hard repair to DIY?
Old 11-21-2010, 04:41 PM
ctwright ctwright is offline
Re: p0410-air pump
Check fuses first, but if it is a bad fuse it might still be the smog pump. Check first just to make sure you are getting power to the pump.
Old 11-21-2010, 06:39 PM
maxwedge maxwedge is offline
A990 racer
Re: p0410-air pump
Water gets into the solenoid/check valve and also can cause this.
Old 11-21-2010, 07:01 PM
Re: p0410-air pump
Fuses are OK.
Old 11-21-2010, 07:08 PM
danielsatur danielsatur is offline
Re: p0410-air pump
This Air pump might have a relay that needs tobe checked.
P0410 Secondary Air Injection System shaundavis108 TrailBlazer | Trailblazer EXT 2 03-29-2010 07:36 PM
'04 trailblazer p0410, secondary air pump kiuppy TrailBlazer | Trailblazer EXT 1 12-04-2008 07:10 PM
Secondary Air pump Code P0410 carczar Grand Prix 5 02-23-2008 09:32 PM
How much is the air pump repair? - Code P0410 hcary Blazer 1 11-30-2003 09:15 AM
