CB Radio Wiring
2003 2500HD w/duramax engine
I am trying to wire up my cb radio this truck. It requires 12vdc to operate but the fusebox has 10, 15, and 25v fuses. Is there a spot to pull 12vdc in this truck? |
Re: CB Radio Wiring
Those are amp ratings, all of those are 12 volts.
ASE Master Certified before the age of 20 Current Cars: 2001 Chevy Silverado 1500 Z71 5.3L 1996 Acura Integra LS B18 1.8L Past Cars: 1990 Buick Estate Wagon 5.0L 1987 Chevy S10 2.5L Tec Four 1995 Pontiac Grand Am 2.3 Quad 4 1996 Jeep Grand Cherokee Limited 5.2L AWD 1991 Ford Tempo L 2.3L 1992 Buick LeSabre 3.8L 1997 Buick Century 3.1L 1996 Lumina APV GT 3.4L 2006 Ford Escape 3.0L XLT |
Re: CB Radio Wiring
with that plug you could easily move cb to another vehicle or put away when not in use.. |
Re: CB Radio Wiring
These trucks have a 12 volt dc electrical system throughout them, the 10 15 25 refers to amps which higgher amps are required for more things being used on a circuit (amps basically indcate the driving force of the electricity in a circuit or how much work that can be done within the circuit).
Ialso agree that you should attach to the port for the cigarette lighter to power the cb system, (some newer vehicles have a noise suppressor built into this circuit) and take your ground lead directly to the battery not the frame, this will help to reduce engine interference through your cb system which wil limit signal strength and shorten communicative distances. |
