Old 11-19-2010, 05:38 PM
derekmci derekmci is offline
low rpms and
Hello
i am havimg an issue with my 2000 ford windstar.
The van starts fine and soon after ideling i notice the rpms needle will start to drop....the van starts to sound as if it wants to stall out. just wondering if anyone could help out with this issue thanks
Old 11-19-2010, 07:05 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: low rpms and
Welcome to the forum!
The first things to check are the usuals:
Dirty IAC valve. Here's a link about how to clean it: http://leckemby.net/windstar/windstar02.html
Faulty/dirty MAF sensor.- to check this unplug the connector to the MAF sensor and see if the van runs better. Give it a clean with MAF cleaner.
Vacuum leaks.- Check all hoses around the intake for rotted/cracked rubber hoses.
Fuel pressure.- you'll need a fuel pressure tester connected to the fuel rail under the IAC valve Key On/Engine off should be 30-45PSI; Key On/Engine Running 28-45PSI.
Best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
hesitation at low rpm and back fire YZ125rider21 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 01-12-2006 12:45 AM
starts up with low rpm and oil light comes on when it hits low rpm,wont rev pass 2000 clough1022 Eclipse Problem Diagnosis 7 08-01-2005 02:49 AM
car wants to die at low rpms, and now i've lost heater fan ryanerik Escort 3 03-01-2005 05:20 PM
Very Low RPM/ and Bogginess-----Please HELP!!!!! summertime_civic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 08-04-2004 05:41 AM
Rough idle and rough at low RPM Ed the Fed Jetta/Vento/Bora 3 11-10-2003 01:15 PM
