Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 11-18-2010, 07:21 PM
TownCarTechi TownCarTechi is offline
Drive Belt Comes Loose !!
I replaced the drive belts on my daughter's '99 2.4L Galant in August. Now, over the past three days, the belt that drives the P/S and A/C has wound off several times. I've checked all the pulleys including the tensioner and they look okay.
The belt I purchased from AutoZone was a Duralast 539K5 which has now been replaced by 540K5. Luckily, AutoZone was willing to exchange the belt so I'm going to attach then new one tonight and hope it doesn't wind off. The new belt 540K5 seems to be slightly thicker than the 539K5.
I also noticed with my naked eye that the engine pulley doesn't seem to line up perfectly with the P/S and A/C pulleys (engine pulley is at the top on the attached picture), but those two pulleys (P/S and A/C) do line up with each other. Has anyone else noticed this?
Old 11-18-2010, 07:54 PM
Obysk Obysk is offline
Re: Drive Belt Comes Loose !!
Is the belt tensioner automatic or do you have manual control over the tension of the belt?
If you have an automatic tensioner I would start by replacing it. More often than not this type of problem is caused by incorrect or insufficient belt tension. Most times you won't be able to "see" a bad tensioner and without a new part to compare it to you won't be able to test the correct tension.
As far as pulley misalignment goes, yes this can be an issue, but if you have never removed or replaced any of your pulleys (and none are damaged) then you can assume that they are sitting in their factory original positions.
I have seen as well the smooth idler pulleys "round off" on the edges causing the belt to eventually ride off the pulley. Make sure you have a very good look at these pulleys.
Let us know what happens and good luck.
Old 11-20-2010, 07:23 PM
The car has a manual tensioner and the pulleys have never been removed (until now). A friend determined that the harmonic balancer is bad. On my daughter's engine, the two engine pulleys (one for Alt and the another for P/S, A/C) and the balancer is combined into one part. The friend says he can get one for $75 (RockAuto lists for $120) and install. If this takes care of it, I'll post again with our success.
Old 11-21-2010, 06:54 PM
Indeed the harmonic balancer was worn and this is why I perceived the outer engine pulley to be out of alignment with the P/S and A/C pulleys. Replaced it and all is good with my daughter's car.
The Following User Says Thank You to TownCarTechi For This Useful Post:
stream (04-14-2019)
Old 04-14-2019, 04:48 AM
stream stream is offline
Angry Re: Drive Belt Comes Loose !!
our Galant had the nasty belt squeal and my husband fixed it but now it is back again, perhaps this is why - very annoying
How to put the drive belt back? serge_saati Windstar 9 10-25-2009 07:55 AM
ball joint keeps coming loose? doberman_52 Century 9 11-15-2006 08:02 AM
bolts keep coming loose. greyjeep Wrangler 1 05-06-2005 09:42 PM
WTH Do Oil Filters Come Loose..? solaris=amazing Engineering/ Technical 13 02-22-2005 10:07 PM
